Temp gauge/boost issue
Old Sep 27, 2019 | 01:23 PM
Evoturbo1's Avatar
Hi all having a bit of trouble my tempeature gauge seems to read almost cold when driving then when I pull up at light it rises to just under half then I move again it returns to cold
But whilst this has happened it seems the car has a mind of its own were boost is concerned it's al over the place it boosts .7 , 1 bar ,1.5 bar ,1.8 bar
I checked and tested the thermostat and it's operating perfectly
Could the boosting issue and gauge issue be related ??
Old Sep 27, 2019 | 03:17 PM
black_beauty's Avatar
I can’t see the 2 being linked. Have you performed a boost leak test? What is your target boost?
Old Sep 27, 2019 | 08:17 PM
Evoturbo1's Avatar
Yes performed a boost leak test seems to be none present
The car should be boosting
1.85 bar
I thought the thermostat/ coolant temp sensor could be having an affect on the gauge and in turn the fueling/boost due to the factd the cts is a engine management sensor
Old Sep 28, 2019 | 10:21 AM
barneyb's Avatar
There is a ground wire, intake manifold to firewall, that if disconnected or bad contact, can produce the readings you describe on the temperature gauge.
Old Sep 28, 2019 | 11:30 AM
Evoturbo1's Avatar
Hi Thanx for that I can only c 1 earth / ground seems to run from the intake to the strut/engine brace is that it ?
Old Sep 28, 2019 | 11:41 PM
Evoturbo1's Avatar
Bump!!!!
Old Sep 29, 2019 | 03:16 PM
barneyb's Avatar
Yes
Old Sep 29, 2019 | 04:36 PM
hutch959's Avatar
if your ground is intact, i would check the wires to the temp sensor and/or replace it.
Old Sep 30, 2019 | 09:51 AM
barneyb's Avatar
The ground being there and connected doesn't mean it is making good contact.
Old Oct 1, 2019 | 07:58 PM
Evoturbo1's Avatar
So the ground is there and making good contact so just to be sure I made a few more grounds I run 1 from the the block to the firewall and another from the gearbox to the body also
I'm thinking it must be a faulty sensor although it wouldn't cause the boosting issues would it ??
Old Oct 3, 2019 | 09:40 AM
barneyb's Avatar
The ground issue affects the temperature gauge. Could it affect anything else - dunno. I mentioned this because it could have been two separate issues.
MrJuls
Sep 20, 2012 03:08 AM
RooDizL
Aug 6, 2005 04:46 AM
morefaster
Feb 26, 2004 10:07 PM
