Driveshaft Options?
Old Nov 7, 2019 | 05:37 PM
PMPN8EZ's Avatar
Driveshaft Options?
I'm getting the classic clunking/slapping sound from my driveshaft getting in and out of the driveway. Rather than try and salvage the "non-serviceable" driveshaft or replace it with the same problematic OEM one, I'm looking to go aftermarket.
Does anyone run this DSS one?
https://www.maperformance.com/produc...YaAs4oEALw_wcB
How is fitment? Were there any modifications needed for the install?
Are there better choices out there?
Old Nov 7, 2019 | 06:07 PM
Hey
Many of the guys are just using the OEM replacement from DSS
https://www.driveshaftshop.com/mitsu...eshaft-w-o-ayc
Old Nov 7, 2019 | 06:53 PM
kpt6's Avatar
Those shafts in the links above are too heavy for the price. For the money, I'd just get a used low mileage OEM one - Chris Barnett on Facebook is a good guy to deal with who parts out lots of Evo's and you might try looking him up. I'm sure he has some spare shafts.
Or find yourself a used AWD 2 piece one that weighs 26 pounds instead. Or have a local shop fab you one.
Old Nov 8, 2019 | 03:07 AM
PMPN8EZ's Avatar
Hey
Thanks. I believe this is the same shaft I found. These are good? I'll have to see if I can find some reviews on them.
Old Nov 8, 2019 | 03:11 AM
PMPN8EZ's Avatar
[QUOTE=kpt6;11892244]Those shafts in the links above are too heavy for the price. For the money, I'd just get a used low mileage OEM one - Chris Barnett on Facebook is a good guy to deal with who parts out lots of Evo's and you might try looking him up. I'm sure he has some spare shafts.
The problem I have going with OEM is, my car only has 60k miles on it & the driveshaft
Is already total garbage.
Old Nov 8, 2019 | 11:52 AM
barneyb's Avatar
[QUOTE=PMPN8EZ;11892264]
The sounds may be classic but are you sure it is the driveshaft? At double your mileage the u-joints in my driveshaft were getting a little notchy but no play that would make noise.
Old Nov 8, 2019 | 01:26 PM
LetsGetThisDone's Avatar
The stock driveshaft is anything but problematic. Are you sure it not just the rear diff clunking?
Old Nov 8, 2019 | 02:06 PM
barneyb's Avatar
I've got some slightly undersize (too short) brake pads on the rear of my car and they make a clunk anytime the wheel rotation direction changes.
Old Nov 9, 2019 | 08:45 AM
PMPN8EZ's Avatar
My driveshaft has been checked and the rear portion is shot. If it had serviceable U-joints to begin with like most normal cars have, I wouldn't need to replace the whole driveshaft. This is problematic, get it?
Old Nov 10, 2019 | 06:27 AM
GSX_TO_EVO's Avatar
https://pstds.com/shop/foreign-drive...er-driveshaft/
This is the shaft I have that’s going into my build. You asked for options and I haven’t seen anyone mention it.
Old Nov 10, 2019 | 09:05 AM
I think this is the first time I've heard of an OEM shaft actually wearing out. And I know a few guys that have close to and/or over 300k miles on their CT9a's...
I've had to have the lobro joint rebuild on a few cars. But that's only the cause the boot tore. It didn't actually wear out.
Old Nov 17, 2019 | 07:08 PM
Balrok's Avatar
As in you're thinking about it or you have it installed and in use already?
Old Nov 18, 2019 | 09:37 PM
GSX_TO_EVO's Avatar
I have purchased it, and it is in my possession. It is not installed on the car currently. Shell is waiting to go into the paint booth then reassembly begins.
Old Nov 19, 2019 | 07:06 AM
ace75's Avatar
I would double check the drive shaft bolts first, if they’re loose, you’ll get a clunking sound.
Old Nov 20, 2019 | 06:51 PM
jxp427's Avatar
Veteran: Air Force
have there been any 1 piece aluminum drive shaft fabs anyone has heard that are reliable or even possible to make?
