JMF mainfold
Old Jan 21, 2020 | 05:45 PM
LetsGetThisDone's Avatar
The manifolds don't creep with RPM really. But none of them run spring pressure.
But to that point, if you want to run 20psi, I don't think an FF turbo kit is going to be the right choice.
Old Jan 21, 2020 | 07:51 PM
justboosted02's Avatar
I always want the option to choose the map I want to run.
thanks for your input
Old Jan 22, 2020 | 09:37 AM
Usman Ali's Avatar
I'm already running 46psi with a map proformance down facing mainfold with a PT 6766 turbo being tuned by john whalen remotely already making 830 hp on a mustang Dyno...buy since I have the full rad and ac condenser the air is some what restricted to make more power...that I why I wanted to go forward face and go a little less boost making close to the same power.....well that's what the aim is anyways.
Old Jan 22, 2020 | 09:43 AM
Usman Ali's Avatar
Originally Posted by justboosted02
wastegate pressure via rated spring is somewhat relative, the problem with a manifold with a poor wastegate priority is boost creep as the flow in the waste gate path cant keep up due to the momentum/velocity of the gas unable to make the abrupt turn in the flow path and therefore more and more gas going through the turbine.
my full race setup did not creep. wastegate pressure was 20PSI
just trying to start a discussion in a dead-ish forum
my map proformance twin scroll t4 mainfold which is NOT a FF mainfold don't creep a bit...always hits the gate Target on gate pressure when I did test it.
Old Jan 22, 2020 | 11:11 AM
You're not going to gain much going to an FF manifold. You won't see it in the dyno anyways.
What size gates are you running? The manifolds I referred to were all running 38mm Tial. So if you're running larger gates that could help.
The worst ones are the manifolds that run a single 44mm. I've seen those not run less than 35-37psi with a 6466, regardless of spring lol
If you're going to change turbo kits, id suggest a better turbo also. The 6766 is a dinosaur. A gen2 6870 will out spool it and make more power.
Old Jan 24, 2020 | 03:40 AM
Usman Ali's Avatar
ya sorry forgot to mention in running 2 tial 38mm wastegates .
it's 6766 gen 2 which was I think updated and rated at 935 hp...so it was perfect for me.
ya so I'm happy with 830ish hp where I'm at rite now all I want is less boost while making at least the same amount of power.
Old Jan 24, 2020 | 08:01 AM
That's not really how it works once in you're in that 800+ range unless you go to a really large turbo (72mm+), which then won't spool well. And probably won't even really run "low" boost like you want.
But I'll tell you I have a car here that make 845whp at 43psi with a gen2 6466. So either your setup isn't quite ideal (cams, intake manifold), or that turbo isn't as great as you think it is and a PTE gen2 6870 would help,
Old Jan 24, 2020 | 12:55 PM
Usman Ali's Avatar
​​​​​​well my cams are gsc s3
intake manifold is meh... race version which I believe was made out of sheet steel.
engine is made my whalen R&D which includes a oring'd block
ya also I don't trust the mustang Dyno I get my car tuned on...it's tells super low numbers...like my friend had his civic tuned on it and it gave 680whp and after 1 month he got it dynoed again on dyno jet and it gave like 730whp on the same setup.
okay anyways let's see how the mainfold comes out will be posting for sure since no one else is lol.
nategleim05
Jul 28, 2012 09:40 PM
jwick76
Lancer Aftermarket Forced Induction Tech
44
Jul 15, 2008 03:57 PM
DTM
48
Feb 19, 2008 09:21 AM
crow
Feb 28, 2005 08:03 PM
Buetang
Dec 4, 2003 01:06 PM
