Evo 5 rebuild 2l
Old Feb 3, 2020 | 01:30 AM
Nebalib's Avatar
Evo 5 rebuild 2l
Hello!
I started evo 5 engine rebuild and i have some questions. Is 2l long rod better than forged 2l option for 500hp? And i f i get long rods how about pistons height, it must be lower its that right? Do i need block machining for long rod?
Thanks!
Old Feb 3, 2020 | 09:07 AM
RS200's Avatar
You probably wouldn't notice any difference with a long-rod engine at 500HP. A lot of the racers don't even use the long-rod on their 1000+ HP cars, so the odds that you would benefit, are slim. If you did choose this route, the piston height has to match (some manufacturers advertise long-rod specific pistons), and the block doesn't need to be notched for any 156mm steel rods.
Old Feb 3, 2020 | 09:14 AM
LetsGetThisDone's Avatar
Long rod isn't even a thing for an 88mm crank. The 150mm rods provides a rod ratio of over 1.7:1 already.
For 500whp, an off the shelf forged piston and budget connecting rod like Eagle will be fine.
Mitchimus
Feb 1, 2015 06:48 PM
mines5
60
Oct 8, 2013 07:02 PM
Uscbryan
Sep 17, 2013 02:28 PM
LacouK600
Sep 5, 2013 11:41 PM
