Accel ignition coil
Old Feb 23, 2020 | 04:52 PM
Apexsilver03's Avatar
Accel ignition coil
Hi everyone, I purchased a cop kit from spoiling up now the cop have failed look up the number on the side of the cop but was only lead to and eBay site. If I would of known it came with eBay parts I would of purchased a different manufacturer for the cop kit. So now that I’m looking for the Toyota Yaris cop I came across the accel ignition coil part# 140078. Has anyone ever upgraded from the oem Toyota Yaris ones? Also is the wiring all the same from the two type of cop that can be used? Apparently there is one that allows the use of the spark plug cover vs one that doesn’t allow. Any help would be appreciated.
Old Feb 23, 2020 | 06:06 PM
gsrboi80's Avatar
Just get a replacement Denso coil/s with the same part number as the others, you’ll likely need new hardware from Spoolin up as well, the star nut on the bottom of the Spooling Up Kit is likely just going to spin when you try to loosen the screw holding the coil to the plate.
It sits so flush on the bottom I didn’t have a tool that would hold it. I ended up cutting through the coil and screw to get it apart when I had 2 coils fail.
Old Feb 24, 2020 | 06:35 AM
The part numbers that I have is 10R-034811 I’ve looked at Denso wed site and no luck. Tried Bosch and no luck. Only comes up a an eBay item and I don’t trust eBay for sh*t. So what part number would be for the Denso cop? Thanks for the response also.
xRoguex
Jul 17, 2019 07:50 AM
EvocentriK
Apr 27, 2019 06:51 AM
butte
47
Jul 24, 2018 08:08 PM
chrisff521
Jun 8, 2012 05:53 AM
Ksyrium11
Jan 11, 2008 05:03 AM
