COP/MSD for 4G18?
Old Dec 9, 2007 | 05:21 AM
Ksyrium11's Avatar
COP/MSD for 4G18?
Hi,
I'm thinking of improving on the sparks being generated in the engine.
Does anyone know what type of ignition are we running? I have two ignition coils that are connected to cylinder 2 and 4, ignition coil on cylinder 2 links to 3 and 4 links to 1.
what do u guys think of MSD and the COP on ebay? Anyone with such mods on NA care to share your experience? Lets say im taking the MSD route, what other items do I need other than the MSD DIS-2 ?
Thanks and regards
Old Dec 9, 2007 | 05:50 AM
Ksyrium11's Avatar
Pics & Diagram
I've attached an electrical wiring of my ignition system and ignition coil, hope it helps.
Old Dec 9, 2007 | 06:05 AM
MalibuJack's Avatar
If it has 2 coils, its a 2 channel system. I have compared the stock coils to evo coils, and the only discernable difference was the boots..
Which leads me to believe that the HKS-DLI2 might be a plug and play option for you to try.. Otherwise you could look at some of the systems done for the evolution and go from there.
Old Dec 9, 2007 | 07:30 AM
DangerousDan's Avatar
what car is this for? the 04-06 RA has coil on plug, one for each plug
Old Dec 9, 2007 | 11:48 AM
Ksyrium11's Avatar
Hi, yeah it has only 2 coils, for cylinder 2 and 4 respectively. 2 connects to 3 via plug wire and the same for 4 and 1.
Thanks for the input on HKS, their products are overly priced IMO that is why i'm looking at MSD and the COP in ebay, furthermore I had something similar to the HKS-DLI2 that boosts the voltage to 16v. I'm looking for a more value for money ignition mod.
Old Dec 9, 2007 | 11:49 AM
Ksyrium11's Avatar
It's for Mitsubishi Lancer with engine code 4.g.1.8. it's not a domestic model found in the states.
Old Dec 9, 2007 | 11:51 AM
Ksyrium11's Avatar
MSD for Evo/Lancer
Do u guys think this would work? need your imputs and I greatly appreciate it.
http://www.msdignition.com/forum/showthread.php?t=4948
Old Dec 9, 2007 | 06:50 PM
otter's Avatar
EvoM Administrator
Moved to Lancer general, since their ignition system is likely more similar to yours.
Old Dec 9, 2007 | 07:04 PM
iufan4lifeul's Avatar
MSD doesn't make ANY products for the mitsubishi lancer minus spark plug wires. Something about our coil packs would malfunction if any aftermarket ignition products were used so says the lead tech at MSD. I have already looked into this.
Old Dec 14, 2007 | 07:34 AM
bahamut's Avatar
Mitsu's coil pack is a "proprietary system". Basically, MSD will have to PAY a portion of money to Mitsu each time one is being made.
IMO, too much work w/o the HP gains. Of course, you may believe Super Street making crazy dyno #'s.
Old Jan 11, 2008 | 05:03 AM
Ksyrium11's Avatar
*sigh*
*sigh*
what a disappointment,
Anyone with such experiences can enlighten on this? like alternatives? seperate setup for the ignition by using the signals sent? They've done it for the evos, COP's on ebay, but unfortunately I will not be able to use the grounding plate due to the layout of my engine bay...
Any imputs?
Gonzothemad
Oct 25, 2008 09:01 AM
joeymia
38
Sep 5, 2007 05:08 AM
LilLancerBoy
Lancer Engine Tech
Jul 22, 2003 08:30 PM
joshkikta
Lancer Engine Tech
May 21, 2002 02:02 AM
