Few Questions on O2 housings and horsepower limits.
Old Feb 26, 2020 | 12:33 PM
Zer0_13's Avatar
Alright.
I am currently building 2 Evos, an 8 and a 9.
The 8 is a 2L running a blouch dominator 1.0XTR.
The more detailed look:
stock crank
manley TT rods
wiseco 9:1 pistons
manley springs,
comp 280 cams,
mil.spec 65mm tb,
strictly modified intake,
STM exhaust manifold,
RC1200 injectors,
walbro 450,
I think thats about it for the important stuff.
The 9 I am yet to even begin, but, plan is either a 2.0L and a BBK-B, or a 2.3L (same turbo) I can list the planned build if needed.
I have multiple O2 housings on hand. A megan, an Invidia, and a MAP 3" Vband and downpipe.
For the current car on stands, the 8, I am debating if I should run the Invidia/Megan or run the MAP 3"? I am trying to debate if this one is going to have a flow rate high enough to necessitate the bigger outlet, or, should I save that for the larger turbo on the next car?
Thank you for any insight people can offer here.
Old Feb 26, 2020 | 01:26 PM
LetsGetThisDone's Avatar
You're not going to be power limited by the O2 housing in either of those setups.
My car makes north of 600whp with a standard open dump O2 housing.
Old Feb 26, 2020 | 01:48 PM
Zer0_13's Avatar
So, you have been running a regular aftermarket unit at that power level with the 2.5" opening? thanks again.
Old Feb 26, 2020 | 01:57 PM
hokiruu's Avatar
People have made great power with those or similar o2 housings on similarly sized turbos. I don't think it will be enough of a restriction to significantly compromise power short of a dump
Old Feb 26, 2020 | 02:13 PM
Yes.
killerpenguin21
15
Sep 11, 2011 06:43 PM
BaumBizzle
16
Jan 5, 2011 02:23 PM
4RETECH
May 10, 2010 08:43 PM
rgar
15
Apr 5, 2010 08:10 AM
EViR
Mar 9, 2010 12:09 AM
