Tuning MIVEC Advance question
Old Apr 15, 2020 | 09:23 AM
240Z TwinTurbo's Avatar
Originally Posted by ConEvo
I am switching to S3's as we speak. But i am keeping r2's too, in case i do not like them, but I have a feeling that S3's on 2.4 will be even better. If i lose maybe a few hunderd rpms probably I will not even notice it enough to bother me. If not, I will move back to r2's
Look forward to seeing your results.
Old Apr 16, 2020 | 05:38 AM
ConEvo's Avatar
Believe it or not, I made 750+whp on pump gas beforei push coolant. Our pump gas is not e85 but it is much more knock resistant than your 93pump gas. We upped the boost on 45psi and we did not even try to push the timing, we left it before even knocked. If you like pm me to send you the dyno
Old Apr 16, 2020 | 08:50 AM
Abacus's Avatar
45psi on any pump gas is asking for trouble. The headgasket expired . An engine is not going to be happy under those conditions.
Its a good idea to run the proper compression/octane for the power you are going for IMO. Good fuel is cheap insurance if you are going to run it hard.
Old Apr 16, 2020 | 08:56 AM
ConEvo's Avatar
Yea man i get it. Probably this time we will lower the boost and try turning the ignition a few degrees. If it makes 700whp I will be happy. I know it is doable, since Aaron from ER made 687whp at 29psi and with a very similar build with mine
Old Apr 16, 2020 | 11:55 AM
Abacus's Avatar
There are limits with octane and cylinder pressure that need to be respected IMO.
With ethanol and race fuel being so inexpensive , I just don't see the point in breaking something on pump gas to hit a number.
Thats an expensive trophy.
SloEvo12
Mar 9, 2015 05:49 PM
211Ratsbud
May 15, 2013 11:08 AM
rampant
Apr 21, 2012 11:25 AM
