Help: Injector Resistor Wiring for Evo 7/8/9
Old Apr 17, 2020 | 10:56 PM
guyver858's Avatar
Can someone help me figure out the correct wiring for the injector resistor wiring for my evo 9? My tuner cut it and soldered all the wires together so I could run high impedance injectors. I am going back to stock injectors so I need to solder the harness back onto the module.
Old Apr 19, 2020 | 11:35 AM
CDrinkH2O's Avatar
Here's the page you need from the Evo 9 factory service manual.
File Type: pdf
Old Apr 19, 2020 | 11:46 AM
Biggiesacks's Avatar
Off the top of my head I THINK as long as you get the white wire to the white wire the blacks shouldn't matter. Basically the white wire supplies power to the 4 resistors, one resistor for each injector. It doesn't matter which resistor goes to which injector. You can test resistance between the white wire and each of the black wires and they should be all the same, but if you check resistance between two blacks it should be double what it is between a black and a white. If I'm wrong about that part then ignore my advice.
05EV08
May 3, 2016 05:58 PM
evolancer04
Aug 4, 2010 09:00 AM
Celica2EVO
10
Oct 10, 2009 09:33 PM
Liqquid
Jan 27, 2009 06:41 PM
dashiet
Sep 21, 2007 10:26 AM
