Flywheel Bolts stuck
Old May 3, 2020 | 04:52 PM
raverthug's Avatar
Im trying to take my engine apart for a rebuild. It looks like the previous owner decided to lock tight tie flywheel bolts. I have a Milwaukee 1/2 and it was able to break 2 free but thats it. Im gonna try heat next but any other options. Ive tried pb blaster and a breaker bar
Old May 3, 2020 | 05:10 PM
LetsGetThisDone's Avatar
How good is your impact? Flywheel bolts are supposed to be installed with loctite. Sometimes you just have to let the impact gun hammer on them a bit.
Old May 3, 2020 | 05:59 PM
raverthug's Avatar
Its a 1/2 Milwaukee cordless, It will keep going but just bounce off but not break it loose.
Old May 3, 2020 | 06:04 PM
You have to hold the gun on their tight. Milwaukee has several levels of 1/2" guns. My 18v fuel breaks them off just fine, and I use plenty of loctite on install.
Old May 3, 2020 | 08:35 PM
raverthug's Avatar
Its the 18V. I was able to get 2 but the other 4 arnt bugging
Old May 4, 2020 | 08:29 AM
blackline's Avatar
5 Year Member
I was in the same boat a couple of weeks ago, got a couple of them out with a snapon 1/2 impact but 2 didnt want to budge. Ended up grinding the bolt head off after trying everything.
Old May 4, 2020 | 08:34 AM
Jp7's Avatar
Jp7
don't you guys have air tools? 1/2" pneumatic....
Old May 4, 2020 | 09:25 AM
My electric is just as strong as my Mac pneumatic gun, and I don't have to drag an air hose around with it.
Old May 4, 2020 | 11:10 AM
heel2toe's Avatar
While a compressor in the shop will never be replaced switching over to electric has been pretty game changing. Even with a drop hose reel the freedom of no air hose is amazing. Electric tool tech has become really good. Surprised your Milwaukee 1/2" wont zip them off. They do have a few levels of the 18v variants but the Fuel is something redic like 1400ft/lbs. Also what are you using for a socket? I know it sounds silly but I swear it hits harder with a deep socket as there is more mass. Just be careful bc the flywheel bolt heads are very small so make sure keep you kep your tool straight on or you run the risk of rounding off the head.
Old May 4, 2020 | 11:57 AM
Also, an impact socket. No chromies
Old May 4, 2020 | 01:00 PM
heel2toe's Avatar
Unless of course the impact socket is 10' away, then use what in reach
But yeah impact sockets are generally thicker (more mass) and they dont shatter and flake off chrome which is nice if you dont want pieces of shrapnel in your face. Can't say I dont use them(read lazy) but one of these times...
Old May 4, 2020 | 01:33 PM
For most stuff the chromes do fine. But when you're using the gun to really hammer down on some extra tight/extra loctited ****, the impact sockets get more of the impact energy into the bolt and you don't have to worry about them exploding.
Old May 4, 2020 | 09:07 PM
raverthug's Avatar
I am using chrome but no flaking. Im gonna try a better battery with a impact otherwise Im not sure. Im doing this in a storage unit so I dont have power but my Milwaukee rivals most pneumatic
Old May 5, 2020 | 05:24 PM
hutch959's Avatar
my extended shaft Ingersol Rand.. with about 120 psi on it will remove or break about anything... lol.
dmonitto
15
Jul 29, 2022 03:26 AM
Olms2468
Dec 14, 2014 01:27 PM
corndog17
Lancer Tranny/Drivetrain Tech
Apr 15, 2011 02:49 PM
