New engine blown 😕
Old Jun 1, 2020 | 04:39 PM
hutch959's Avatar
that damage doesnt look like detonation (E85 is very resistant to knock)...
that damage looks like dirty oil and viscosity break down to me.
i have a filter on my FF... i come out of the turbo with a 90 degree elbow into a fairly large K&N filter.... fits right behind the grill
RazorLab's Avatar
E85 knocks. Who started this redonkulous idea.
Either way, put a filter on it.
Old Jun 1, 2020 | 05:04 PM
kpt6's Avatar
Knock knock.
Who's there?
E85.
E85 who? E85 never ever ever knocks! You must be 93 or 91!
I kid. I kid.
Old Jun 1, 2020 | 10:56 PM
Pal215's Avatar
Probably too many miles on dirty, dusty roads with no filter. Still, I would like to know what your PTW clearances were.
Old Jun 2, 2020 | 12:22 AM
Wheelspk's Avatar
The car was hardly driven for 4k to 5k miles but YES without a filter mostly coz I couldnt import one coz all the flights were cancelled coz of covid...
but I did measure the pistons they were 85mm im guessing the ptw would be 85.2 but I would had to conform that from the builder, as I said it was made by a well known builder so I dont think its the builders fault.
Old Jun 2, 2020 | 12:25 AM
Wheelspk's Avatar
Originally Posted by hutch959
that damage doesnt look like detonation (E85 really doesnt knock anyway)...
Yes i got a shorty k&N filter but coz of covid I received it later about 4k miles later ... but running with no filter did its damage i guess, as well did a lot of WOT pulls on the highway for tuning with a mesh on the turbo ...i was running 5w40 in the winters and 10w40 in summers....thr car was broken in 10w30 NON synthic oil as we do sae30 in my country.
Old Jun 2, 2020 | 10:00 AM
LetsGetThisDone's Avatar
The car wasn't "hardly driven" 4-5k miles. It was driven 4-5k miles, simple as that.
PTW clearance is measured with a micrometer and dial bore gauge. You can't guess.
Old Jun 2, 2020 | 10:01 AM
Wheelspk's Avatar
Yup I have asked the builder for the specs
Old Jun 2, 2020 | 11:06 AM
Dallas J's Avatar
Veteran: Army
The specs on pistons for PTW are always very tight where 4g motors always seem to do best with about 50% bigger clearance. Too tight and this stuff happens. We've always shot for 4-4.5 thou IIRC.
Old Jun 2, 2020 | 11:47 AM
4 is about minimum. If it's only going to make 400whp, tighter is ok but not needed either. Once more than 6-650whp is the goal, it starts going up.
Old Jun 2, 2020 | 12:28 PM
Dallas J's Avatar
Veteran: Army
Yeah, and if you follow the manufacturers spec they claim 2-2.5 or something crazy. So if that motor was just built to spec it was probably way too tight.
Old Jun 2, 2020 | 12:52 PM
kikiturbo's Avatar
PTW depends on piston material and power target.. Stock pistons work at silly low PTW because that alloy doesnt expand much. Mahle racing pistons in 4032 expand less than wiseco's that use 2618 (or similar)... so a Mahle in 4032 alloy will work fine with 2.3/1000 inch, stock pistons run 0.8/1000 inch, and wisecos will run 4 - 4.5/1000
It will be interesting to see which PTW this build used, was it built with tq plate, and what is the real cyl size measurement....
Old Jun 2, 2020 | 12:58 PM
Abacus's Avatar
I'd prefer a tighter PTW with good fuel/tuning on my own engine .0035 or so
PTW has come down over the years with better fuel, tuning and material. Back in the day people had to run them loose to live. Well, some people still have to run them loose to live.
Old Jun 2, 2020 | 01:01 PM
Pal215's Avatar
I wouldn't exclude them just yet. You'd be surprised to see how many reputable builders and machine shops have goofed up engines.
Old Jun 2, 2020 | 01:21 PM
Fadi Barakat's Avatar
i ran no filter bringing a car back home to AR from NY that i bought. Engine started knocking as soon as i got home. thinking debris got in it.
