I have 4 DTC codes, abs & acd lights always on -EVO 8
Im not sure if I am supposed to post this here, but any help or advice will be much appreciated about the following DTC codes 45, 72, 73, 65. I have attached a photo
45 - Open or short circuit in pressure sensor Set when voltage on pin 38 of ACD plug C138 is less than 0.2 V. Check pressure sensor wiring continuity and sensor resistance (should be 2-3 Ohms)
73 - Open or short circuit in Left valve system - Check valve wiring for continuity. Check valve resistance is less than 4.7 ohms
72 - Open or short circuit in Right valve system - Check valve wiring for continuity. Check valve resistance is less than 4.7 ohms
65 - Open circuit in ABS monitoring system or faulty ABS - Set when ABS is operating continuously for more than 1 minute. Check harness and connectors between ACD ECU and ABS
