Bent my intercooler!
Old Apr 14, 2004, 10:54 AM
Vroompsh's Avatar
OK...so i was parking my car last night, everything is cool...and i hear this loud crunch i get out to see the damage, and it seems that i've hooked my front bumper on a tire stop, parking barrier, whatever (those concrete things that stop your car when you pull in). Well, usually you can clearly see these things, and park far in back of them, but this one was made of TARMAC and its BLACK! So, i had no idea it was there. Anyway, i hit the plastic piece under the bumper which the intercooler brackets are connected to, and the bracket in the middle pushed in the intercooler a bit. Just in the center, the very bottom row on the intercooler was pushed up, but not even touching the row above it. Do you think it will be ok? The tech at the dealership said he saw no cracks or leaks, but in the summer heat here in the DC area, it might...What do you think?
thanks
Old Apr 14, 2004, 11:25 AM
pensacola_evo's Avatar
might want to look into a new after market intercooler and than you'll be adding some more power and looks with it.
Old Apr 14, 2004, 03:07 PM
Vroompsh's Avatar
yeah, i mean of course i'd do it if i had the money, but right now that's not an option. I just hope its ok for now...
Old Apr 14, 2004, 03:28 PM
Zeus's Avatar
...you'll only add power if it is leaking...
Old Apr 14, 2004, 09:41 PM
bishiboy's Avatar
Zeus, are you saying by adding a bigger aftermarket IC, you don't gain power?
I strongly disagree. Depeding on which IC you get, most have a higher flow rating the stock, and most are more efficient at cooling charge air than stock.
Higher flow + cooler air charge = higher power (via more timing advance, faster spool up, higher potential boost)
Old Apr 14, 2004, 10:24 PM
Zeus's Avatar
Sorry, two conversations, one old mind... I was talking to someone else about the Buschur unit. I think you would agree that I'm opinionated, but not a fool...
i64X
Evo X How Tos / Installations
138
Feb 27, 2016 03:30 PM
jwick76
Lancer Engine Tech
14
Nov 1, 2012 06:47 AM
planb x
Mar 29, 2012 12:21 PM
AMS
Automotosports - Illinois
15
Oct 23, 2006 10:34 AM
idriveawhiteevo
Jun 3, 2004 12:37 AM
Quick Reply: Bent my intercooler!
