disengage push style clutch
Old Sep 17, 2020 | 03:44 PM
itsjustaplant's Avatar
I'm taking off my transmission on my Evo 8 and I am at the point where I separate the throw-out bearing from the pressure plate. My problem is that my car has been converted to a push style clutch, so there is no release fork to push before prying with a screw driver. How do I disengage it so I can pry it apart?? The clutch is a carbonetics, not sure if they made the push kit or if it is another brand. Thanks!!!!
Last edited by itsjustaplant; Sep 17, 2020 at 03:46 PM. Reason: forgot to ask question
Old Sep 17, 2020 | 04:31 PM
hutch959's Avatar
if its a push type... it should just come off.
there is nothing for it to lock onto.
the throw out bearing is built into concentric slave cylinder
Old Sep 17, 2020 | 04:36 PM
Oh so no need to even mess with trying to pry them apart, it just slides off when the trans is pulled?
Old Sep 18, 2020 | 08:23 PM
hutch959's Avatar
correct...
when you get it off and look at it.. you will understand
Ckeesee12
Jun 27, 2020 01:19 PM
Rom
Feb 26, 2017 06:28 PM
jamaicaboost
Dec 17, 2016 09:46 AM
twinturbogreg
Nov 15, 2010 03:07 PM
brandon1304
Aug 2, 2008 07:13 PM
