HTA71 with 2.3 Stroker and FD bad mix?
Old Jan 11, 2021 | 01:59 PM
evo8vz's Avatar
I remember I use to run an OG green with 2.3 and peak tq was at 3800 but 470 tq which was undrivable some times.
I built another evo but with hta71 wonder how it will be.
This one has cb extemeport intake manifold, 70mm throttle, 5 inch ets core and r2 cams...other car didnt have nice.mods lol
Old Jan 11, 2021 | 03:27 PM
Abacus's Avatar
Yes, unless you are doing auto x you are choking the engine. The HTA powerband comes up quickly and then tapers hard. Its a stock turbine wheel I think its too small for even a stock engine. The 4g63 goes well to 8000 and should have a properly sized turbo .
I would use a Red or Black with a 100mm crank. Larger powerband and the engine will live a better life.
Old Jan 11, 2021 | 04:18 PM
evo8vz's Avatar
Yeah my old car was very choked but thing was like a V8.
Car was quick ran 10.9 on the og green with a 2.3 and BC 276....with nothing ported and ebay fmic
roll racing thing would jump in front of cars then choke out on 3rd gear
Old Jan 11, 2021 | 05:22 PM
justboosted02's Avatar
i ran a stock evo 8 turbo on my 8 with a 2.3 for a few months and it made full 25psi by around ~3k and fell flat on its face above 5k
it was a laugh but wasnt very practical. I suspect that you would feel the same way
FWIW the end setup on that car (at one point the car had a 3076/evo 8/S200sx) was an HTA green and it was a very fun autox/TT car
Old Jan 11, 2021 | 05:44 PM
evo8vz's Avatar
on the og green it fell flat around 6500-6800 got longer gearing though
hta71 should spool quicker though
Old Jan 12, 2021 | 12:55 PM
Abacus's Avatar
If its over 2:1 for backpressure (more then likely it is) its like running a marathon while breathing thru a straw.
On my stock 2.0 MHI fp red It was at 40psi back pressure at 30psi of boost IIRC. Add a bigger engine and a smaller turbo and the results get much worse.
Turbojunkie
Jun 26, 2014 02:48 PM
TK40
Mar 8, 2010 11:58 PM
importjake00
ExtremeTurboSystems.com – WA
May 8, 2008 11:56 AM
05-EVO-GSR
11
Sep 29, 2007 05:16 PM
