Quiet whine in 3rd and 4th?
Old Feb 9, 2021 | 01:43 AM
trvr's Avatar
I read posts for hours looking for an answer or similar situation but I cant find anything that seems to match up. I will start with a short parts list for context.
BLOX subframe mount
3" straight pipe
ACT ME2HDSS clutch
ACT streetlite flywheel
stock tune / drivetrain
pretty much 03 evo 8 otherwise (other mods not relevant to this issue) 136k miles
So, I just did the clutch and figured I would do fluids as well, my car was due anyway. I used mitsu oem fluids, MTF 75w85 and LSD SAE 90. 3qts in my trans, put 1 qt in my tc, drove it to the gas station in back, drained excess from fill plug, per the Jack's write-up. I am an incredibly paranoid mechanic, hense the HOURS of reading on my car. I drove around a listened very carefully to my car to very nothing sounded like it was gonna blow like an A6M Zero. The car was down for 4 months (long story and some 2 months of back order and a bunch of curve *****) so I cant remember every single sound it made but I tried to place all the normal creaks and groans she made prior.
Ive got normal drivetrain noise in 1st and 2nd that I always had but in 3rd and 4th there is an easily missed whine. I think I might hear it in 5th but I think it is road noise at the speed I am going because I have some noisier all seasons. the whine is only really easy to hear between 2000-3000 rpm and is much quieter in 3rd than 4th. It is only on accel and gets slightly louder up to 3k rpms. I wanna say its tc but I dont know if I cant hear it past 3k rpms because of the exhaust or its going away. no gears grind, no pop outs, drives smooth. I dont feel like its death whine because I dont hear it in 5th or at high speeds. There is not grinding but I dont recall ever hearing it. I am wondering if its only im 3rd and 4th because those are my most frequently uses gears.
https://youtu.be/Au8fOnZ1uNQ
https://youtu.be/YKG6YSRvyaE
the sound in the beginning of both of these videos, before the sound of doom and apocalypse begins, is the closest I can find to the whine im hearing but mine is MUCH quieter. I dont think I could pick it up on video. Normal? Should I add fluid? Rebuild? Sell it and move to the country?
Thanks for bearing through a long post and any ideas about my car.
Old Feb 9, 2021 | 04:29 PM
hutch959's Avatar
have you checked the t/c fluid level since the whine started?
Old Feb 10, 2021 | 06:02 PM
trvr's Avatar
i did and added a little more, doesnt seem to have changed much, I drove to work with the extra fluid in it and i plan on checking it again when i get home.
Old Feb 11, 2021 | 04:54 PM
hutch959's Avatar
sounds like the transfer case to me.
but odd that it all of a sudden started after the clutch install
i hear that flywheel rattle too...
maybe get up on a lift and see if you can hear if its the transfer case or the trans
Old Feb 11, 2021 | 10:34 PM
trvr's Avatar
im gonna head to the dealer and pick up some more mtf and try to add a little in the morning then i got an appointment at 4D engineering to put in on a lift and have them listen to it because im stumped
doesnt sound like clutch noise, i had a 6puck before with a loud rattle and i was certain to use loctite and torque the flywheel to spec so my best guess is maybe trans. i added 3qts but maybe i need to put a tiny bit more. I appreciate the ideas
Old Feb 13, 2021 | 09:13 PM
Jonno99's Avatar
Always pump the tc from the bottom, then drive then pump again
Old Feb 14, 2021 | 01:12 PM
trvr's Avatar
ironic
funny enough, t case is just fine. my noise is my transmission as I found out this weekend..
deadstockkpomp
31
Oct 13, 2012 11:57 AM
Guitarplyr
22
Jan 12, 2012 01:29 PM
TurboIX
Oct 29, 2009 10:26 AM
EVIL_EVO_VIII
55
Jun 26, 2006 06:47 PM
vicbdn
21
Dec 17, 2004 08:52 PM
