help..
Old Apr 6, 2021 | 02:58 AM
SwabeLife's Avatar
help..
Hello guys my question is when I go WOT 3rd gear rpm cuts at 6k rpm and i when I go WOT in 4th gear it rpm cuts at 5K rpm. any suggestions. car pulls strong its just the rpm restricts for going further. car mods build buschur 2.0LR, flex tuned I have e85 in the tank, haltech elite 2k pnp ecu, pte 6262 gen2 turbo. thanks in advance
Old Apr 6, 2021 | 08:24 AM
justboosted02's Avatar
do you have failsafes setup in the ECU?
AFR out of range?
Old Apr 6, 2021 | 04:30 PM
hutch959's Avatar
what boost level?
what plugs? what coils? what gap on plugs?
Old Apr 6, 2021 | 05:00 PM
SwabeLife's Avatar
AFR out of range?
14-16 afr. I do have failsafe in haltech 2k pnp ecu
Old Apr 6, 2021 | 06:00 PM
something might be off with the car mechanically causing the ecu to protect the motor. You should most likely go see your tuner.
SwabeLife
Apr 23, 2021 07:29 AM
IREVO
Dec 24, 2005 04:27 PM
PVD04
Nov 8, 2004 01:31 PM
rt turbo
17
Aug 5, 2004 05:37 AM
