Car blocks when trying to start driving
Old Apr 11, 2021 | 07:07 AM
Anders97's Avatar
I Just got a problem with my evo ix mr 6 speed
I was driving normal and fine for about an hour with no problems, parked the car for about an hour and when I try to go front or back the car rolls about 30 centimeters ish when Im goung off the clutch and totally blocks, this happen also in nautral and all 6 gears, i dont think its brakes because when its blocks it kinda roll the other way then what way i was driving if you understand what I mean.
im not sure but don think its the clutch too because the pedal feels normal and before the car blocks i start driving like normal.
everything worked perfect before i parked the car, anyone have some tips or a conclusion for the problem or had the same problem?
sorry for my bad english, im from norway
Old Apr 11, 2021 | 08:09 AM
RallySport9's Avatar
Did you do a high rpm clutch drop? Any loud bang before parking coming from driver train? Does the car shake when putting it in first and getting off the clutch pedal? Sounds like it could be tcase.
Old Apr 11, 2021 | 08:34 AM
Anders97's Avatar
no bad sounds from clutch or anything, no shaking or anything, but how can the transfercase stop working by stand still an hour? I rally cant understand this problem
no bad sounds from diff or tcase when I try to go forward og back
Old Apr 11, 2021 | 08:47 AM
Biggiesacks's Avatar
does the car roll freely in neutral? Inspect the intake piping to see if any of them have popped apart. Is it throwing any codes?
Old Apr 11, 2021 | 08:55 AM
Anders97's Avatar
the car still get blocked in neutral, what should i look for at the intake piping?
no codes, the car is exactly what it was before, no bad sounds or anything exceps its get blocked when trying to roll
im very confused about this
Old Apr 11, 2021 | 12:53 PM
if it's not moving in neutral it's probably your drivetrain. You will need to get the car in the air and start spinning wheels individually to see if you can isolate what's seizing up. If that's outside your capability then it's time to take it to a shop.
Old Apr 11, 2021 | 10:27 PM
Anders97's Avatar
yes, i have no garage or no place to look at it so my car wil get towed to my nearby mitsu shop
dinok
18
Dec 23, 2010 08:19 AM
kanyewest
Jun 29, 2007 07:37 AM
ciclon1
Jun 5, 2005 04:25 PM
Go_Lancer_Go
Lancer Troubleshooting
Dec 27, 2004 09:46 AM
yellowcar
Sep 8, 2004 01:09 PM
