Arlington Machining Oversize Headstud Washers
Old Jun 4, 2021 | 05:51 PM
blackline's Avatar
5 Year Member
I've been looking for a set of over size washer for my Evo 8 head with ARP 625 studs. We know the washer ARP supplies will dig into the head when torqued over 100ft.
The solution was to get a set of Whalen Speed washers but I've been unable to source it from them. Arlington machining out in Cali has his own set that fits like a glove.
ARP Washer size:
OD: 0.8115in(20.61mm)
Arlington Washer size:
OD 0.9475in(24.07mm)
As you can see, it's a whole 4mm bigger which fits like a glove in the washer groove.
Front
Back
Comparison of the washer in the head
Install Pics in all 10 slots.
Old Jun 5, 2021 | 09:41 AM
CDrinkH2O's Avatar
Great info thanks! I see they have no web site. T: (951) 359-0710
Old Jun 5, 2021 | 12:38 PM
LetsGetThisDone's Avatar
I never had an issue with the Whalen washers, but since he stopeed selling them, i started using ARP 200-8532. Which is 7/8 OD (.875") with a chamfer.
Old Mar 13, 2022 | 08:48 AM
krys88's Avatar
I was about to install those washers but that's what I just read from maperformance website " They are not of the hardness required for use on cylinder heads, mains and connecting rods."
Old Mar 22, 2022 | 01:27 PM
They're 8740 chromoly, which is....hard. Not sure why MAP's website says that. All the washers in the ARP stud kits are same material.
autotechnica
Jun 24, 2013 07:18 PM
Anarchy99
Aug 1, 2012 08:57 AM
TD05HR
Jul 12, 2005 06:58 AM
