2.3L 6466 E85 blue smoke when you blip throttle at decel and at idle
Old Jun 30, 2021 | 07:53 PM
Wirk's Avatar
Hey guys, just trying to see if anybody has had a similar issue. When cruising or after wot and the car decels, When i get back on the throttle I have a blueish /white smoke coming out the exhaust. Also during cold start it does it intermittently and goes away. Not sure if its from condensation though or cause of e85. I have about 1500 miles on this new build including turbo kit. Car pulls great, compression test results came back as 162,160,160,160. Leak down at 6%,8%,6%,7%. Just didn’t know what else I should be checking for.
Build List :Kiggly HLA
GSC S3
Supertech Inconel Exhaust +1mm
Supertech Black nitride Intake +1mm
Supertech Valve Guides and seals (standard)
GSC beehive valve springs with Ti Retainers
ARP cam tower bolts
ARP Cam Sprocket bolts
GSC Zero Tick Lifters
Fluidampr Crank
Manley 100mm Billet Crank
Wiseco 1400HD 85.5 Pistons .020 oversize 9:1
Manley Turbo Tuff W/ ARP 625+
OEM MLS gasket
ARP 625+ aged headstuds
ACL Bearings
Sheepey Forward Facing 6466 Gen 2 V Band Kit
-3an feed line with no extra restrictor just the one that comes with the 6466 and a -10an drain
Full titanium exhaust from the turbo back
Sheepey Catch Can kit with I believe -8 and a -6 line
Here are some videos and thanks in advance!
https://youtu.be/aWX38fyZjR8
https://youtu.be/3-1nuTnJTWs
https://youtu.be/TKSxbpEHBwc
Old Jul 1, 2021 | 12:09 PM
RazorLab's Avatar
Make sure the drain is straight down on the PTE turbo.
I also had to add a restrictor to stop my BB PTE's from smoking. I can't remember the size but I had to go down pretty significantly to stop the smoking.
Old Jul 2, 2021 | 07:00 AM
Wirk's Avatar
Thanks, I called PTE and was recommended to install a turbosmart pressure regulator. I ordered the new precision full flow drain fitting and may try a restrictor for now to see how it goes.
Old Jul 6, 2021 | 09:52 AM
LetsGetThisDone's Avatar
Put a .030" restrictor in the turbo feed line.
Old Jul 6, 2021 | 03:08 PM
Wirk's Avatar
Ordered a .035” last week. Will update. Took exhaust manifold off looked dry did not look to be valve stem seals. Also removed downpipe and checked back of the turbo. Also looks dry.
Bananaevo9
24
Sep 26, 2020 04:47 AM
A872B
Mar 23, 2020 03:48 PM
AshK
Mar 13, 2020 09:18 PM
Phoenix*
13
Feb 20, 2011 11:37 AM
sunrichmond
Nov 29, 2010 07:05 PM
