Enough fuel for 550whp?
Old Nov 6, 2021 | 12:48 AM
envdevo9's Avatar
Currently have a walbro 450 and precision 1200cc. Is this going to be enough for 550 on e85?
Old Nov 6, 2021 | 08:13 AM
Based on my E85 setup i think youre going to be close on the 1200cc injectors. You should specify whether this 550 is based on Mustang / Dynojet
Old Nov 6, 2021 | 09:17 AM
envdevo9's Avatar
This would be on a dyno jet.
Old Nov 7, 2021 | 08:51 AM
Abacus's Avatar
I don't think you are going to get to 550whp on E85 . I ran ID1300's and added a gallon of pump 93 each tank to bring the content to E70ish to give the injectors some headroom. I had a 450/267 pump with a boost a pump . A 450/274 has a higher pressure relief so that would also help. I made 500-530whp on E70ish on a dynojet .Important to note I only turned 7800-8000rpm. Higher rpm will need more fuel.
There was also an EFR 2.3 on ID1300's on E85 that was out of injector at 530whp years back.
You could move into a larger injector.
Increase base pressure
Lower content to E70 (If you are really going to run it hard I would add MS109 or C16 for octane)
Old Nov 7, 2021 | 10:13 AM
Thanks for commenting Tim. I just know at my 460 DJ WHP on E85 running RC1000cc injectors, i have very little head room (high IDC). Really needed larger inj's for my tune but it still runs hard years later
Old Nov 7, 2021 | 06:06 PM
LetsGetThisDone's Avatar
You'll need Fuel Injector Clinic 1650 HiZ's to safely make that power.
Old Nov 8, 2021 | 07:45 AM
schuhie's Avatar
I'm just going to echo what everyone else said. I was running FIC 1100s or whatever on E-85 and was pretty tapped out in the upper 400s. After a built motor, moving to a double pumper and an FP red, I went to the ID 1700x injectors and have plenty of headroom in the upper 500s. I don't have a log in front of me but if I remember right I'm in the upper 70s-low 80s IDC currently.
Old Nov 8, 2021 | 09:38 AM
envdevo9's Avatar
Thanks for the info everyone
evo101395
13
Jun 22, 2011 12:44 PM
evoson23
Mar 26, 2010 10:59 AM
matyb
32
May 28, 2007 12:51 PM
