evo map sensor problem
Old Dec 7, 2021 | 03:29 AM
zachgordon's Avatar
hi everyone i am chasing a problem with my evo that i have been having for a while now and i suspect its my map sensor
i have the stock evo 8 map sensor (md305600)
i have constant 5v on the power line and a good earth
at atmospheric pressure with the ignition on but engine OFF i am getting 1.91v on the signal output wire
can someone please confirm what voltage output this sensor should be producing with ignition on but engine off
thanks so much
Old Dec 7, 2021 | 05:00 PM
zachgordon's Avatar
Bump anyone ??
Old Dec 11, 2021 | 11:41 AM
CDrinkH2O's Avatar
To check your MAP sensor outputs the correct voltage, back-probe the yellow wire on terminal 1:
Old Dec 11, 2021 | 12:29 PM
240Z TwinTurbo's Avatar
1.90V is 31 units in the MAP Table so if you can find the EVOScan formula for the OEM sensor you can calculate the pressure. I couldn't readily find the equation after looking for 10 minutes.
Old Dec 11, 2021 | 09:16 PM
zachgordon's Avatar
i cant seem to find the equation either on evoscan
so im safe to assume that my map sensor is bad if its reading 1.90 at atmospheric pressure ?
Old Dec 12, 2021 | 11:27 AM
CDrinkH2O's Avatar
Yes!
barneyb
Nov 19, 2018 01:44 PM
hyeteck
Jul 16, 2011 03:56 PM
SSKILLA
Mar 31, 2008 08:16 PM
vroomevo
Jan 12, 2007 09:07 AM
vroomevo
Jan 7, 2007 08:10 PM
