Spark Plugs / Sputtering / Oil Found
Old Jul 23, 2022 | 07:31 AM
Smoknzx3's Avatar
get one of these guys to set the gaps. Worth the cash for
sure
Old Jul 23, 2022 | 08:50 AM
sasha1712's Avatar
sure
just bought one from amazon. Cheers
Old Jul 24, 2022 | 11:05 AM
sasha1712's Avatar
.20-.22 disregard my “9” in the iridium plugs. The 9 is a step colder.
Is that 0.20mm?
Smoknzx3's Avatar
Originally Posted by sasha1712
Is that 0.20mm?
yes
Old Jul 24, 2022 | 01:04 PM
Evoryder's Avatar
Hey,
I would recommend a leak down test. I doubt that oil is coming from the valve cover. Definitely change the plugs and hope for the best. More than likely it will run good for a few runs and once the plugs become fouled again then it’s going to go back to breaking up.
Old Jul 25, 2022 | 08:17 AM
Smoknzx3's Avatar
Yeah, I think he maybe right. The oil looks like it’s dripping down the plug, which would suggest the oil is coming from the cylinder.
Old Jul 25, 2022 | 11:49 AM
sasha1712's Avatar
Originally Posted by smoknzx3
yeah, i think he maybe right. The oil looks like it’s dripping down the plug, which would suggest the oil is coming from the cylinder.
Old Jul 25, 2022 | 11:52 AM
Smoknzx3's Avatar
the leak down is more for the valves but with that much oil I’d think more of the rings, but I guess it’s also possible to leak down through valves stuck open. The only reason I said the valve cover gasket is because it actually did fill the spark plug hole in my car. But I’m about ready to drive mine off a cliff.
Old Jul 25, 2022 | 11:58 AM
Evoryder's Avatar
Leak down and a compression test will tell the story of what’s going on with the motor. Worn or damaged rings can be exposed by a leak down too
Old Jul 25, 2022 | 12:00 PM
Smoknzx3's Avatar
Something is definitely not right.
Old Jul 25, 2022 | 04:26 PM
hutch959's Avatar
iridium's don't make anymore power.. or make the car run any better that i can tell.
they just last longer.
and since you dont really know your issue yet, copper plugs are alot cheaper and easer to gap
Old Jul 26, 2022 | 10:40 AM
sasha1712's Avatar
Hi
just done a compression test. Not sure what the figures should be?
cheers
Old Jul 26, 2022 | 11:23 AM
The EvO9 manual notes the following in PSI (145 max to min 92): Compression pressure (250 r/min) kPa (psi) /1,000 (145) / Minimum 637 (92)
Old Jul 26, 2022 | 12:56 PM
bcollins92's Avatar
Does your intercooler piping have oil in it?
Old Jul 26, 2022 | 01:19 PM
sasha1712's Avatar
no 👍
