Big Turbo Build Questions
Old Apr 6, 2024 | 07:14 PM
Todd Marshall's Avatar
Hi everyone!
I'm close to finishing my big turbo build and need some insight. I'm running a t3 open scroll dual wastegate with a Pulsar 6466. I'm wondering if I set this up correctly.
The wastegate side ports are teed and connected to port 2 of my Grimspeed EBCS. The tops of my wastegates are plugged. I wanted to make sure this was correct.
Port 3 would go to the compressor housing of the turbo via vacuum nipple. I'm unsure what would be the size of this vacuum nipple fitting that would go to the turbo. I provided a picture and maybe someone can tell me.
The last concern would be what would be the best way to prime the turbo? I've seen different methods and just want to make sure things are done correctly. Once everything is said and done, I'll gladly post a build thread that's about 5 years worth of data 🤣. Thanks in advance!
lockadam2112
Jun 23, 2011 04:54 PM
Onkar02
Lancer Aftermarket Forced Induction Tech
14
May 10, 2008 06:06 PM
cantcatchme96
65
May 4, 2008 12:11 PM
topherhook
64
Mar 13, 2008 07:34 PM
Mirage2.0
Dec 15, 2007 01:11 PM
