Need turbo lag advice
Old Jun 29, 2024 | 06:23 PM
  #46
MikeDizz's Avatar
Originally Posted by SnailSpeed
g30-660 will definitely spool faster but will fall short of your power goal. And depending on the current mapping of boost control, if this is part of the issue then you might run into a similar problem with the g30-660, we need to see duty cycle in logs or a picture of the duty cycle in the map.
So these are the wastegate parameters I found through ECU flash
Old Jun 30, 2024 | 03:16 AM
  #47
SnailSpeed's Avatar
Yup as I suspected and many others. The wastegate duty cycle should be 100 percent up until the turbo starts to really spool, so basically should be 100 to about 4500rpm and start to taper off a bit as boost comes on. Not sure how much of a difference it will make but it will make a difference, send me a message I can tweak it for you if you send the map.
I will also post mine once my evo tuning laptop charges, although I have the 62mm and I’m running less boost it will give you an idea of what I am talking about.
Old Jun 30, 2024 | 03:23 AM
  #48
SnailSpeed's Avatar
Here is my duty cycle table to give everyone else an idea, this is controlling a dual port internal wastegate actuator on my twin scroll mhi housing AGT 62mm
Old Jun 30, 2024 | 06:56 AM
  #49
MikeDizz's Avatar
He is a well known tuner out here on the island could there be a reason why he set up the table like that? I know once it crosses over 5k boost starts to come on fast. If I adjust my WGDC I'll most likely have to adjust my fuel and timing correct?
Old Jun 30, 2024 | 11:55 AM
  #50
SnailSpeed's Avatar
Some “well known” tuners have been known to not have a good grasp on tuning. I have had to redo many tunes for other people tuned by “reputable” tuners. Not saying he’s a bad tuner as one can’t judge a tuner by wastegate duty cycle tables alone but kind of does tell a story. Im just saying just because a tuner is well known doesn’t mean he knows what he’s doing or is the best at what he does.
Now in regards to a reason it might be done this way, sometimes when tuners know you have a stock bottom end and need to limit tq they will intentionally set up wastegate duty cycle this way. And other times tuning smaller turbos you don’t have to work as hard to get them to spool fast so even if you put 0 duty cycle early on they still spool fast.
And making the changes I’m suggesting may actually not make any difference but my bet from my 10+ years of tuning cars not just Evos is that it most likely will pick up a few hundred rpm of spool(my 62mm picked up like 600rpm of spool once I set up the duty cycle to what you saw in the picture I posted). You might have to make adjustments to the fuel mapping but again, if you want help just send me a message and we will see if it makes a difference or not.
Old Jun 30, 2024 | 12:00 PM
  #51
MikeDizz's Avatar
Ok thanks. Maybe your right about the torque statement. I bought the car "built" but at the end of the day who knows what the guy actually put in it. Right now the car is making enough that I really hope it's not a stock bottom end lol. When I get to my laptop later I'll send the rom over
Old Jun 30, 2024 | 03:24 PM
  #52
LetsGetThisDone's Avatar
That tune is not causing turbo lag. Wgdc is 100% below 180 load, and the Wgdc tables look fine. It's a laggy turbo.
LSs1Power
38
Dec 8, 2016 10:46 AM
JSAI
11
Jun 8, 2014 03:55 PM
street2dirt
May 7, 2013 07:42 AM
Kidloco51
83
Aug 3, 2011 04:00 PM
fknchristoph
12
Dec 3, 2010 07:09 AM
