Anyone with P0401 CHECK ENGINE LIGHT?
Old Apr 22, 2004 | 07:04 AM
NRG's Avatar
NRG
I got this P0401 check engine light and it is representing EGR - insufficient flow. I checked everything and it seems fine. I cleared the code with a scanner many times but it just keeps coming back.
Any knows the cause of this or have encounter the same thing?
Old Apr 22, 2004 | 07:22 AM
webguy330i's Avatar
https://www.evolutionm.net/forums/se...by=&sortorder=
Old Apr 22, 2004 | 07:31 AM
NRG's Avatar
NRG
Yeah I read all those but haven't found a fix for my particular problem. As I stated, all my hoses and valves are operational.
Old Apr 22, 2004 | 07:34 AM
nastea1's Avatar
where is the EGR hose specifically, i have this issue also
Old Apr 22, 2004 | 07:44 AM
Fas4dr's Avatar
Tucked under the throttle body.
Old Apr 22, 2004 | 07:53 AM
nastea1's Avatar
left side, middle ???
Old Apr 22, 2004 | 09:40 AM
Fas4dr's Avatar
if you are standing on the driver's side looking at the throttle body, it is directly underneath it facing the firewall.
Old Apr 22, 2004 | 04:08 PM
Nad1370's Avatar
I believe it could be a VSV (vaccum switching valve) that is stuck partially closed you need a scanner and a vaccum pump with a gauge to check tis valve that is controlling your EGR operation.
Or just take it to the dealership to have it diagnose under warantty ( make sure your stock if you plan to visit)
Old Apr 22, 2004 | 07:49 PM
NRG's Avatar
NRG
I FIXED IT!!!!!!!!!!!!!!!!!!!!!!!!!
Remember I said all connections seems fine??? Well THEY ARE NOT!!!!!!!!
You have to put your hands behind and under the EGR valve to feel it. So you can't see if there is a disconnection of one of the hose.
Just remember there are two hoses that connects to the EGR valve, and one of mine was off. I got a feeling it will come off again so I suggest you guys with the same problem as me to put a zip tie on there.
Hope this helps some of you guys!! Let me know if it worked too!!
Old Aug 26, 2012 | 12:46 PM
hoof hearted's Avatar
I too had this code pop up...
It was INDEED the two hoses under and behind the TB had popped off!
Thanks for an easy fix!
tonydith
Nov 6, 2016 08:46 PM
mdknutsen
Jun 11, 2016 03:58 PM
breadn56
May 14, 2016 07:04 PM
Jaxson75
Lancer Troubleshooting
Jul 24, 2015 08:41 PM
Liquid0401
Sep 6, 2013 06:18 AM
