Help- car won't turn over???!!!
Old Apr 24, 2004 | 02:36 PM
Stockfornow...'s Avatar
I just reconnected my battery after removing it to do the under-hood bushings, tried to turn the car on and....it won't turn over.
All the electrical stuff comes on no prob, radio, fan, IC spray, lights, but no starter???
I called my local dealer thinking I may have reset the key codes, but that is not the case. He said if that were the case, it would turn over but not start.
Any ideas, if not I am looking at an expensive tow on Monday.
I visually checked the larger fuses next to the battery, and the one on the posistive terminal, all those were fine.
Thanks in advance.
Jerry
Old Apr 24, 2004 | 02:41 PM
nastea1's Avatar
hrmm what did you disconnect, something is disconnected... double check everything.
Old Apr 24, 2004 | 03:02 PM
DOH DOH DOH
After checking every possible fuse (all ok) I decided to just make double sure I connected the battery correctly etc. AND LOW AND BEHOLD I did in fact disconnect a plug block, the one directly behind the battery towards the firewall. Reconnected that and bingo, it starts, man I feel dumb sometimes, but at least I didn't have to pay for a tow.
Old Apr 24, 2004 | 03:04 PM
nastea1's Avatar
at least you figured out!
Old Apr 24, 2004 | 03:06 PM
MalibuJack's Avatar
Yep.. one of the power leads is disconnected.. does it click when you try to start it? or get nothing? There's a large fuse on the positive battery clamp, check to make sure that its not damaged and nothing got snagged.. Also there's a relay on the battery tray, make sure you didn't knock the connector off (or the junction next to it)
NSDQ
Jul 15, 2014 07:03 AM
MurderedOut09
Jan 11, 2014 08:47 AM
LancerEVOmann
Apr 26, 2007 07:53 PM
team_ghost
Aug 27, 2006 01:09 PM
Racer1
Feb 28, 2005 08:32 PM
