TRANNY HELP! My dealer is screwing me!
Old May 6, 2004 | 07:01 AM
sillypuddy's Avatar
gokou..
if your aftermarket shifter causes a problem (note the IF), how can you say mitsubishi sucks in quality.. you changed the car.. if you put a dead rat in the engine, are you going to blame them for the subsequent blowup?
-joe
Old May 6, 2004 | 10:59 AM
GOKOU's Avatar
Originally Posted by sillypuddy
gokou..
-joe
I've use short shifter on my honda and toyota with no problems. If a short shifter can cause transmission problem then Mit have a bigger problem that they need to address. Quality sucks! Better Design it better! It just goes to shows why they are going bankrupt.
Old May 6, 2004 | 11:13 AM
batty's Avatar
hmm dont know what to say. but i can say the drivetrain on a EVO is more brutal then ur Acura. 2500 miles went in for repair . I am assuming you broke it in properly. Also I know my friend a short shifter installed wrong **** grinded like crazy. And eventually just ruined the transmission. wonder if that was the case in ur situation. Both times your trans went u had the BM shifter installed. And you only know if it was installed right.
Old May 6, 2004 | 11:20 AM
batty's Avatar
Old May 9, 2004 | 07:23 PM
jbrown's Avatar
It shifts fine into every gear, I don't try to "slam" 2nd, but it never grinds going into any gear, and I do drive a tad aggressively from time to time. Before I put the shifter in, it would grind on the 1-2 shift when done too quickly, so I stopped doing that altogether. The stock one just felt sloppy and vague, with the B&M I am much more confident about what gear I am going into each time.
MagicManRed
596
Dec 9, 2020 07:59 AM
nefariousdeeds
11
May 17, 2013 12:56 AM
NOMIEZVR4
Oct 16, 2011 03:34 PM
Dammit Cubs
May 29, 2008 09:09 PM
dklau33
Mitsubishi TC-SST Discussion
39
Nov 26, 2007 05:20 PM
