knock?
Old May 4, 2004 | 10:17 AM
chris86530's Avatar
Question knock?
hey guys, i was just wondering what exactly knock is? I have my S-AFCII tuned for it, but i guess there's not much point in seeing it if I don't know what it is...also, what are the safe and recommended levels of knock? Thanks alot
Old May 4, 2004 | 10:25 AM
nastea1's Avatar
knock is defined as detonation and is very bad for an engine..
http://www.stanford.edu/~bmoses/knock.html
Old May 4, 2004 | 10:29 AM
chris86530's Avatar
ok, i understand now, so what should my evo's maximum safe knock reading be at at idle, mid range rpms, and high rpms?>
Old May 4, 2004 | 01:42 PM
chris86530's Avatar
cmon guys? i need to know so im positive im not hurting my engine
Old May 4, 2004 | 01:45 PM
chickenbrest's Avatar
I would like to know as well.....
anyone? anyone? anyone?
Old May 4, 2004 | 01:54 PM
evolutionist's Avatar
There are many discussions about this, do a search after you read this for more detailed information.
If your car is not very warm, meaning it has been running for 15 mins or so, then 25 to 70 is fairly normal. On a long trip, a hour or more then 100 to 190 might be a normal count. When the engine is very hot pre-ignition is more likely to happen. It also depends on what grade gas you have. Hopefully you will never get "real'' knock. Your car pulls timing before it gets out of control. The knock sensor tallys vibration, knock, ect. It is really guessitmating the vibration. It is there just to pull timing. I hope this helps.
Heezayx
Dec 12, 2011 06:07 AM
H8ted1488
Nov 2, 2010 04:22 AM
steelcityevo8
16
Dec 25, 2005 12:27 AM
racegate
AEM EMS
Jul 17, 2005 01:35 PM
EVOMIZ
AEM EMS
May 2, 2004 01:19 PM
