knock values, are they legit??
how legit is the knock reading of the afc, i calibrated it as the directions specify, but i always get knock values ,just wonderin what other people are experiencing with the afc and knock
My knock value is 0 most of the time. When it's cool, it's 0 even when i'm revving over 6000. when it's hot, knock value shows somewhere between 10-30 at idle. Higher when it's really hot. Even when it's really hot, as I start the car and rev up to 3-4000, knock value goes to 0. When it's really hot and rev up to 6000 or so then knock value goes to about 40.
my air-fuel ratio at idle is -3% and at 6000rpm high throttle is -15%.
Originally Posted by Ryuji ATC
So how does SAFC come up with those numbers?
the SAFC II does not properly interpret our ECUs knock signal form our knock wire
it's like me speaking japanese to you. you can hear the noise but can't seem to figuring out what i'm saying beside guessing it. Yes it's made to read knock but not for our car.
Originally Posted by evodan2004
is there a knock light or sensore we can get that is acurete. post links please. thanks.
if you want to read knock, get and www.pocketlogger.com and look at your timming curve, if it's diping as it climb that mean you're knocking.
trust me on this. For some peoople the knock reading is 0 all day, and for some it;s like 24-80 counts
Originally Posted by honda-guy
just because the knocks read zero all day doesn't mean it's not working, it just mean your car is tuned properly and you are not getting any knocks as it should be. for those who have knock readings above 20 all day at all rpm range, it could be that they didn't calibrate it correctly. i just want to see some confirmation from Apexi that this feature was not design for the Evo.
Wrong, my SAFC knock is at zero all the time, but i can see knocking within the Pocketlogger. little dips here and there.
