MBC Install Probs. Help!?!
Old May 15, 2004 | 09:11 PM
EVOTEXAS's Avatar
I installed a Hallman RX Pro tonight and I am experiencing the symptoms of having the tubes hooked up to the wrong openings of the MBC. Except I have that part right. I tried a few configs and finished here - and it still doen't work. I can get 11 psi with a spike to 12. I have the sideways opening of the MBC now T'd into the vaccum line between the BOV and intake. I have the straight end opening of the MBC connected to the wastegate actuator. I have the vaccum tubes to the stock solenoid removed and the intake tube hole plugged along with the turbo outlet hole plugged. What the hell is the problem?
Old May 15, 2004 | 09:54 PM
projekzero's Avatar
with any manual boost controler the fitting opposite the adjustment knob will go to the source, or in your case line ot the bov/intake
the line with the fitting 90 degrees from the adjustment knob goes to the wastegate actuator.
if you havent already, try switching the lines.
Old May 15, 2004 | 09:57 PM
projekzero's Avatar
http://www.slowboyracing.com/Boost%2...BC_hookup.html
Old May 15, 2004 | 10:01 PM
EVOTEXAS's Avatar
projekz, that is how I have it. I described it wrong in my initial post.
Old May 15, 2004 | 10:09 PM
projekzero's Avatar
take it out and take it appart (if it will come apart) make sure it was put together right, ive never seen a hallman put together wrong, but once i got this cheap piece of junk and the spring was installed before the ball (wtf?), the wastgate stayed open all the time and the car wouldnt boost over 11, if not try using the turbo outlet as a soure instead of the bov line
Old May 15, 2004 | 10:11 PM
MalibuJack's Avatar
how many turns is the valve opened at this point? I had to open it several (2??) turns before I got boost up around 18 or so PSI where I could tune it.. Look for a blockage or kinks.. also verify the "Weep Hole" isn't blocked (if you look in the side of the fitting you should see one of them on the MBC has a small hole in it..)
EDIT: Oops.. this is the hallman, it has a ball/check valve, it should be opened all the way and then tightened to restrict flow through it.. When its fully opened, shake it to make sure oyu can hear the ball moving in it....
Old May 15, 2004 | 10:12 PM
EVOTEXAS's Avatar
I will take it apart. I tried using the turbo outlet the first time I hooked it up. Didn't work.
Old May 15, 2004 | 10:13 PM
projekzero's Avatar
https://www.evolutionm.net/features/...machvcorner/30
Old May 15, 2004 | 10:16 PM
projekzero's Avatar
malibu is right, with any boost controller youll have to turn em several turns before they will even raise the boost at all
Old May 15, 2004 | 10:27 PM
03EvoVIII's Avatar
I have a Hallman, I would check to make sure it is hooked up right like everyone else has suggested. For me I actually had to switch springs to get it to make enough boost...
Old May 15, 2004 | 11:10 PM
EVOTEXAS's Avatar
Yup, I finally got it. I took it apart as suggested by projektz and the light spring had to be removed as it did not fall out. I decided to put the heavier spring in and reinstalled it. This is time it would boost to about 13 psi so I pulled into a gas station and popped the hood and turned it two full turns and now it holds almost exactly 19.5 to redline. How's that for quick tuning? Hehe, the install took 7 hours though. Haha. Thanks for all your help guys. Should it feel night and day faster? Because it doesn't....
Old May 15, 2004 | 11:15 PM
projekzero's Avatar
i'm glad, i think everyone who posted on here had good input, made it very easy to fix the problem
Old May 16, 2004 | 04:56 PM
berkel's Avatar
Hi,
A Hallman MBC was basically my first mod and no, it didn't make a huge difference, but it did help somewhat. If you do exhaust mods and fuel tuning to feel a nice difference. I'm looking forward to cams for even more of a meaty powerband.
Take care,
FB
Old May 16, 2004 | 05:11 PM
MalibuJack's Avatar
Yeah, I agree.. holding boost through redline made the car feel alot better, but not super dramatic.. when I added the 3" turbo back exhaust and a filter (though I don't really recommend the filters without tuning for them) it was like night and day.. woke the car up alot.
Old May 16, 2004 | 07:01 PM
EVOTEXAS's Avatar
Awesome, thanks guys. I currently have the Hallman putting 20.5 psi to redline, a K&N drop in with the top cut open, a Perrin cat delete, a custom 3 inch catback. How much HP do you think I am putting to the wheels? I am getting the basic dynoflash on Friday. How much HP after the flash? Thanks!
cnoevo8
Jul 5, 2011 11:27 AM
hydroshock
Sep 30, 2009 04:42 PM
E\/0IXG$R
Aug 10, 2007 06:49 PM
redevo8driver
Aug 31, 2004 05:15 PM
umiami80
Feb 15, 2004 06:59 PM
