stalling issues after walbro fuel pump install
Old May 19, 2004 | 10:29 AM
Secret Chimp's Avatar
Originally Posted by Quickshift
As far as reseting the ecu it only take a couple minutes. Just pump your brakes like Kiss said . I have reset mine in about 1 min a couple times. The way you can tell your ecu is reset, is it will start to idle at about 1600 rpm for a bit while the ecu adjusts fuel and timing. But from the symtoms you said it almost sounds identical to my freinds problem.
To further refine this, it only takes a few secs to reset your ecu after you remove a battery cable. You do not have to hit your brake pedal to get it to reset either. Just undo the battery cable...hold it in your hand....count to 10.....then bolt down the cable. Your ecu is now reset.
SC~
Old May 19, 2004 | 10:43 AM
Quickshift's Avatar
Ive had mine not reset from doing that. I disco the battery on mine for about 20 sec hooked it back up and wasnt reset . So just FYI sometimes there will be some left over juice somewhere.
Old May 19, 2004 | 01:43 PM
arpad's Avatar
Should I reuse the old fuel filter or use the one included in the Walbro kit?
Old May 19, 2004 | 02:24 PM
Quickshift's Avatar
I reused mine but if the kit comes with a new one might as well put it on.
Old May 23, 2004 | 12:46 AM
arpad's Avatar
Thanks again for the suggestions; resetting the ECU didn't help, and I pulled out the pump and double-checked everything, but it all seemed to be in order. I contacted the company I bought it from (lancershop.com) and they were really cool about it, they're sending out a new one. I'll update with results after I install it...
shane_evo7
Mar 7, 2019 05:49 PM
STIU2SLO
Feb 14, 2017 02:21 AM
khay silk
Dec 5, 2015 11:21 PM
89turbosupra
Oct 17, 2015 03:57 PM
5LEEPERISAH23I
Dec 30, 2011 05:14 PM
