Best piston rings
Old May 24, 2004 | 01:57 AM
andber's Avatar
Best piston rings
Hi,
Which piston rings do you guys recommend as the best?
Do you know anything about Hastings piston rings?
Thanks.
Old May 24, 2004 | 04:29 PM
mdzuricky77's Avatar
In my opinion JUN are the best. You can pick them up at www.boost-solutions.com
Old May 24, 2004 | 04:52 PM
Aby@MIL.SPEC's Avatar
Depends on your application / frequency of replacement, etc. Standard old ductile rings are ok for standard driving & seat good & quickly. They dont stand up to super abuse.
chromoly rings can take punishment better, but take longer to seat properly. Readily available.
moly filled rings are not that great IMO, vastly depending on vendor as the moly eventually falls out over time.
titanium nitrated rings take the most abuse, last a very long time & depending on how the liner / bore is honed, can take for ever to seat/seal.
You just have to ask yourself what your intent is, how often do I want to change these rings & do I mind using a little oil over time?
1 thin compression & low frictiion oil control ring is best for power.
look for the thinnest compression rings possible if overall power is your goal & dont mind replacing your rings in 5-10k miles. Your mileage will vary by application/abuse!
Old May 24, 2004 | 08:44 PM
projekzero's Avatar
or as wot posted above you can use a combination of different rings
cerevo
12
Sep 9, 2016 03:45 AM
Igaly1021
Aug 15, 2016 07:56 PM
Fishd0
34
Apr 11, 2013 12:48 PM
ezzey
Dec 6, 2012 09:58 PM
konstantinosIX
20
Oct 26, 2008 06:09 PM
