The Turbokit is out and it's sick
Old Jul 17, 2004 | 12:33 AM
  #721
alex_alex's Avatar
Sigh. After a long and hard look, and many many hours of consideration, i probably won't go with the 3071 turbo anymore.
I spoke with Vishnu the other day, and from what i understand, Shiv wasn't too happy ith the 3071 b/c it lags about as much as the 3037 but makes nowhere near the power.
Maybe ill try Buschurs stock turbo upgrade and have Shiv tune it.
Old Jul 17, 2004 | 01:18 AM
  #722
Az3ar's Avatar
dont know man my turbo has full spool at 3900 rpm
Old Jul 17, 2004 | 01:23 AM
  #723
Az3ar's Avatar
I mean all the people in the 1AUG socal EVO meet will see my EVO. they will even see the 3900 rpm full boost
Old Jul 17, 2004 | 02:11 AM
  #724
EVOVII_SWE's Avatar
Don't know about real life but in theory the 3071 is spot on. It has the exact same turbine as the 3037 with a slightly smaller compressor, 71mm compared to the 76mm on the 3037. This should give less lag but also a bit less power, the laws of physics once again I have a hard time seeing why ATP uses the 3071 in their kits that are supposed to give a quick spool and good driveability if it really doesn’t? As they say they have put months of dyno testing to achieve the perfect "compromise" so to speak. The 3071 is rated to 450hp and the 3037 to 500 so it will of course give less power but you should gain on better spool instead. I have yet to see a 3071 kit installed on a car with more supporting mods to see what it’s really capable of. My car probably won’t be ready and tuned in another three weeks or so, still some waiting until I can test and see for my self.
AMS also use the 3071 but their figures seam high, they state 575hp on that, don’t know how but they also state 650hp for the 3076 which to me is the 3037. On their page they state spool to be 3000-3600 rpm on the 3076 and 3200-3800 on the 3071 but I guess they must have mixed those up cause if that’s correct there should be no reason to go for the 3071.
Old Jul 17, 2004 | 07:23 AM
  #725
AMS's Avatar
AMS
Yes Thomas, I just noticed the spool up numbers yesterday, they where mixed up when they where put up on the website. The numbers on the website are crank hp and figure about 15-17% loss. The numbers also represent the maximum the turbo will support.
-Martin
Old Jul 17, 2004 | 09:46 AM
  #726
Quickshift's Avatar
Hey Az3ar are you using both springs with the tial wastegate? I talked to paul and he said to use them both for a 21psi wastegate.
Old Jul 17, 2004 | 09:51 AM
  #727
2k4EvoVIII's Avatar
When i ordered my kit i just ordered the 1.4 bar spring with it. Is that not what you guys ordered? I had the assumption if was just one spring? Guess we will see Monday!
Old Jul 17, 2004 | 09:59 AM
  #728
Az3ar's Avatar
Yup 2 springs. I think blue and green 21~22 psi
Old Jul 17, 2004 | 10:03 AM
  #729
Az3ar's Avatar
Hey How did u install your ARP head studs??? by the way with all the mods that you have now and the kit I wont take under 390 whp on pump gas.
Old Jul 17, 2004 | 10:32 AM
  #730
shiv@vishnu's Avatar
Who told you that? Looks like I'm going to have to withhold next Friday's Hooters company dinner from someone
shiv
PS. BTW, I like the 3071. It's certainly the least laggy of the upgraded turbo options on the market for the EVO. I think the confusion comes from the fact that my personal preference is the 3037. It's my opinion that if you are going to do a turbo upgrade, do one that *just* meets your boost response requirments and has the highest flow potential. From what I've seen, the 3037 fits this bill for most customers (and myself). Not all, but most that i have seen. Yes, it does spool up ~300rpm later than the 3037. However, it's transient boost response at engine speeds well above the boost theshold (say 5000rpm) is extraordinary and on par with the factory turbo and far ahead of any of the old-school non GT turbos from the T-series family. It's basically a big turbo that behaves, in my ways, like a small turbo. That's what makes it so unique, IMHO.
Old Jul 17, 2004 | 10:36 AM
  #731
Zeus's Avatar
Doh!
Old Jul 17, 2004 | 05:14 PM
  #732
Quickshift's Avatar
I did them one by one on my car , I will pm you the link with the info i left it is somewhere on this site . Did them in my freinds car too so it works well doing it that way,
Old Jul 17, 2004 | 05:19 PM
  #733
2k4EvoVIII's Avatar
Can you PM me that link too. I found a thread on here that tells you how but i just want to make sure that it matches what you did since it is proven to work.
Thanx
Old Jul 17, 2004 | 10:28 PM
  #734
alex_alex's Avatar
shiv
Haha. Sorry, shiv, i won't get him in trouble then. And sorry to everyone else including Az3ar for the post then. Apparently i was misinformed.
Old Jul 17, 2004 | 10:29 PM
  #735
alex_alex's Avatar
Shiv, are either one of these turbos (the 3071 and the 3037) adequate if I only plan on running 91 octane all the time? Or would the compromise in lag be much more than the benefit of the extra power ?
