Denso IW24 vs NGK BPR8ES
Old Sep 16, 2004 | 12:34 PM
3deep's Avatar
Why not use the ngkIX iridiums only $7.99
Old Sep 16, 2004 | 07:52 PM
prowler's Avatar
I have been wondering when I need to swap out the plugs. I am approaching 11,000 miles.
Old Sep 16, 2004 | 08:42 PM
marksae's Avatar
Anyone ever order their plugs from ngk.com before? If so, what are your experiences with them. I'm thinking about getting my plugs from there.
Old Sep 16, 2004 | 09:00 PM
marksae's Avatar
Are our stock plugs NGK or Denso?
Old Sep 16, 2004 | 10:28 PM
scherejs's Avatar
i believe denso is the stockers, but can't remember. i have denso iw24 in mine now and it's never ran better.
Old Sep 17, 2004 | 06:00 AM
QuantumEVO's Avatar
NGK IGR7AG
Old Sep 17, 2004 | 07:08 AM
Smogrunner's Avatar
How do you gap iridium plugs? Mine came at .029 and that is too wide. Then, the typical tap, tap, to narrow the gap didn't work and I didn't want to damage the plug. Friends said you can't gap them yourselves. True?
Old Sep 17, 2004 | 07:22 AM
berkel's Avatar
Iridiums are a ***** to gap.
I broke a few when I tried to gap some NGK iridiums for my wife's WRX.
I had the Densos IW24 and I was getting misfire either because they were fouled from running too rich and/or because they were gapped a little too wide. Anyway, you need to be very careful. The instructions say to not even try, but it can be done.
The Densos came at ~.028 which is pretty good.
Does anyone know where the stock plugs should come gapped at? ALso what the NGKs (iX) referenced in this post should come gapped at? I will either try the coppers next, they're easy to gap, or get another set of stock NGKs or the NGKiX if they are gapped appropriately.
Finally, Iridiums should have a fairly long life, similar to platinum as long as they don't foul. Coppers you would want to replace more frequently. In my previous cars (Integra GSR with N20 and Audi Ar 1.8T) I used NGK coppers and changed them every 10k miles or less. I've already switch to the Densos at 15K, then back to the stockers at 20k (I have 24K miles now). I'll probably change them at 30K...
Take care,
FB
Old Sep 17, 2004 | 08:32 AM
PVD04's Avatar
According to www.z1auto.com, they should be gapped at .028
Eisen7
11
Feb 28, 2020 12:42 PM
TrendSetter
19
Jun 2, 2017 11:30 AM
fantrman
Nov 30, 2015 04:29 PM
Done
210
Apr 4, 2015 10:47 PM
brakeboost980
26
Apr 3, 2015 02:17 AM
