View Poll Results: how often do you change your evo's oil
3000 better safe than sorry
81.55%
7500 dealer suggested?
3.88%
10000 some people say thats all synthetic needs
1.94%
Other interval. Make sure to post what it is.
12.62%
Voters: 103. You may not vote on this poll
Oil Change
Old Jun 3, 2004 | 10:40 AM
GOKOU's Avatar
The number is there for reference. Take a look at the oil and if it's dark and dirty then change it even if you just change it the other day. Commen sense!
Old Jun 3, 2004 | 11:20 AM
Nellie's Avatar
I'm not sure I understand the meaning of dirty oil.
Won't oil pick up carbon deposits from the engine and hold them in suspension?
Won't the filter remove larger deposits?
Isn't this what both are designed to do?
Oil will never remain clear and it's not designed to do so. With modern synthetic oil which does not breakdown as dino oil does, you can extend oil changes with complete safety. 5,000 mile oil change intervals are still erring on the cautious side and probably by only changing the filter at 5,000 miles, you could extend the oil change to 10,000.
Bottom line - change as often as makes you comfortable, but don't think you need just because the oil looks dirty.
Old Jun 3, 2004 | 11:30 AM
19.5PSI's Avatar
i don't drive me EVO that often so i would do mine at 7500.
Old Jun 3, 2004 | 11:57 AM
OnlineAlias's Avatar
Originally Posted by ArCaNe50
15000 miles thats crazy is that for their turbo charged cars too? I wonder if porsche turbos use the engine oil or not and if that has any effect on it.
Porsche's (911) have a dry sump. They have a TON of oil to contaminate before they need changed...
The manual states 3000 for hard use 5000 for light use. Do what the manual says, because if you have an engine failure everyone, the dealer, the service guys, the manufacturer, everyone, is going to point at those numbers before they will cover you.
Old Jun 3, 2004 | 12:03 PM
moogle's Avatar
Every 2000 miles.
I change with royal purple 15-50 and mobil 110 oil filter.
You'll feel it on your butt dyno how smooth it is.
Old Jun 3, 2004 | 12:17 PM
mifesto's Avatar
15-50? dude u do realize its abit thick right? i mean your not living in the arizona desert
Old Jun 3, 2004 | 12:45 PM
ArCaNe50's Avatar
That makes me feel a little better I will do between 3 and 5G then. BTW does any one use redline oil. Do you know where to get it?
Old Jun 3, 2004 | 01:05 PM
GOKOU's Avatar
If you can't use judgement by looking at it then I suggest you leave it to chance. I know I wouldn't. Try looking at it the oil when you fist put it in. After a few days and then after few months. You will see the difference.
Old Jun 3, 2004 | 01:31 PM
ArCaNe50's Avatar
hes right it gets progressivly darker. you should be able to tell. Do all you guys change your own oil or do yo have the dealer do it or what?
Old Jun 3, 2004 | 01:47 PM
kdogg's Avatar
Really? Do you? I mean, my oil looks crappy after a week. Changing the oil every other day would get expensive and time consuming. I thought someone said synthetic is "dirtier" looking?
Old Jun 3, 2004 | 02:25 PM
Nellie's Avatar
Yep - I agree it looks darker. I guess my point was it's meant to (holding particles in suspension, etc.) as it's doing it's job. The color of the oil (dark, light, black, etc.) shouldn't be the determining factor in deciding on an oil change.
Again, go with an oil change period that you feel comfortable with, but 5,000 is fine and very conservative.
Old Jun 3, 2004 | 03:02 PM
GOKOU's Avatar
If your oil looks crappy after a week then you need some engine work/cleanup depending on what you mean by crappy. By all means do what you think it's right for you. I don't use a certain mileage point to change my oil. I check the oil regularly and change it base on time and appearance.
Old Jun 3, 2004 | 08:45 PM
gnulooks's Avatar
I use Mobil 1 in both my turbo and non-turbo vehicle. The Evo gets a oil change after 3,000 miles because the engine runs really hot. In my other 4 banger n/a car, I change the oil at 7,000 miles because the car runs at lower rpm's and does not run quite as hard or hot as my Evo. I periodically check the oil in both vehicles and I can tell you the n/a car oil seems to stay lighter longer. On the other hand, the Evo oil at around 2,000 miles starts looking like the 5000 to 6000 mile mark on my n/a car. This is the reason why I do my oil changes at every three thousand.
Old Jun 10, 2004 | 03:10 AM
moogle's Avatar
Its better if its thicker. I mean doesn't matter if its in arizona desert when your racing **** is hot as hell.
Old Jun 10, 2004 | 03:27 AM
NvsEvo's Avatar
i will never go over 3,000.......the cleaner the oil, cleaner the egine...just my .02
