injector and pump- somewhat of a problem
Old Jun 4, 2004 | 12:56 AM
odie3283's Avatar
Just installed my stage 4, 680cc injectors i believe, and the 255 pump...
Starts, idles, drives fine....
when i get on it a little it sputters and hits fuel cut and whatnot...tried setting the MBC at 20 where it was but spiked to like 23, then turning it down a tad made it sputter slightly less...
Let it be known that i have absolutely no tuning done on the car...No SAFC or flash of any sort...Basically that is what i think is the problem, correct?
Just need a 2nd opinion, or any other ideas?
Also thinking of putting in a colder plug than stock tomorrow
Old Jun 4, 2004 | 06:20 AM
Speedlimit's Avatar
Admin Emeritus
You need to control AFR's now with a flash or piggy back or aftermarket ECU.
Speedlimit..
Old Jun 4, 2004 | 07:24 AM
EvolvedDSM's Avatar
Ummmm..... yeah. So, you put in larger injectors, but have no way of controlling the extra fuel. Therefore, you're dumping so much gas in the engine that it can barely keep itself running. The sputtering is not fuel cut. It is the inability to completely ignite an overly rich air/fuel mixture. A colder plug would only worsen the condition. Put your stock injectors back in until you correct it via Speedlimit's advice.
Old Jun 4, 2004 | 09:02 AM
sccavee's Avatar
I can't believe it would even run. I'm taking a ton of fuel out with my injectors and pump.
Old Jun 4, 2004 | 09:48 AM
erioshi's Avatar
You are definitly running too rich. Your ECU is opening your new fuel injectors for the same amount of time with more fuel flow that it was using for the stock, lower flowing injectors.
Oops - missed the cams in your sig...
Old Jun 4, 2004 | 09:58 AM
odie3283's Avatar
Thanks guys...
I knew it was the tuning
Old Jun 5, 2004 | 10:33 AM
odie3283's Avatar
And i did have a code for engine overboost
and my car is definitely running lean
Old Jun 8, 2004 | 09:38 AM
V8 HUNTR's Avatar
i dont mean to judge, but i dont think there is any way that your car is running lean right now..... should be PEG rich..... like blue smoke out the back rich !!!!
Taylor
Old Jun 8, 2004 | 09:40 AM
odie3283's Avatar
You guys didn't catch on to my sarcasm yet...
i usually mean the exact opposite of what i say, as indicated with the
Old Jun 8, 2004 | 09:42 AM
MalibuJack's Avatar
Yeah, you definitely need a bit of fuel management.. closed loop and idle after the car warms up will be ok.. but open loop will blow black smoke and foul your plugs in no time.. If you need a quick fix, pick up an S-AFC.. but Personally my (admittedly biased) recommendation is the TurboXS Utec..
Quickshift's Avatar
Ya if you used buschurs stage 4 injectors settings, those are race gas settings. Need to richen it up about 12-14 pts on the highend from 3400-7800. I have pretty much the same setup.
Old Jun 8, 2004 | 03:29 PM
erioshi's Avatar
When I posted I had missed the cams in your sig. I was thinking you were running pig rich on stock cams with bigger injectors and the high flow pump. Whith new cams in addition to the other changes, you absolutely needed proper tuning to be sure of what your car was/is doing.
yikez
74
Jan 22, 2011 09:33 PM
nscahall
Mid-Atlantic Region
Jun 24, 2010 01:34 PM
bboy_RES
Apr 10, 2010 06:01 PM
Trader Vic CT9A
Mar 23, 2009 02:18 PM
95lsvtec
33
Jan 28, 2009 10:58 AM
