Boost gauge problem
Old Jun 7, 2004 | 05:42 AM
scott88vr6's Avatar
Boost gauge problem
Anyone out there ever have any problems with their Defi- D boost gauge. When the car is cold, everything works fine. After driving the car and parking it, starting it again a few minutes later, I don't read any vaccum? I read boost just fine, butno vaccum at all. After driving it a couple of minutes, the vaccum side of the gauge starts working. Pulled the car into the garage, let it cool down for about an hour tried it again, and everything works fine. Checked all the connections and everything was good. Any suggestions. Could the vaccum line from defi be collapsing on itself from the heat?85-95 outside.
Old Jun 7, 2004 | 06:12 AM
vittorio's Avatar
I second that.Exactlly the same thing happened to me last nite.I had different history,but still.My inercooler pipes got loose and I my engine shuted off.After I adjusted the clammps back on while driving back home wasnt reading any vacum.I got D-series as well.
Old Jun 7, 2004 | 06:17 AM
scott88vr6's Avatar
It sucks doesn't it, you wonder what is going on with your car! I just don't know if it is the gauge, or the vaccum tubing.
Old Jun 7, 2004 | 06:22 AM
mikesevo8's Avatar
Where did you tap the vacuum for the guage ???
This sounds like another persons problem when they tapped the line betwwen the FPR and the solenoid.
Vacuum comes and goes as the solenoid turns on and off.
The fix was to tap between the solenoid and the manifold.
Probably not your problem as you can read boost but not vac.
Old Jun 7, 2004 | 06:25 AM
scott88vr6's Avatar
Thats where I put it, but why is it that it only happens when it is hot outside?
Old Jun 7, 2004 | 06:26 AM
vittorio's Avatar
Another thing,now that freeaking gauge is reading 2 psi more than my boost controller.Before they were right on.Wonder if somebody else has the same issue.Did Your clamps get lose at all?
Old Jun 7, 2004 | 06:31 AM
scott88vr6's Avatar
the vaccum on the gauge has been working fine until the temp outside started to rise?
Old Jun 7, 2004 | 06:32 AM
scott88vr6's Avatar
None of the clamps are loose. Everything is good
Old Jun 7, 2004 | 06:41 AM
sr20det91's Avatar
Definitly sounds like it was tapped in the wrong place. Mine used to do the same exact thing before I changed it.
The best place to tap is the short line coming off the top of the left side of the intake manifold before the seloniod, but if thats where you already have it, it has to be a guage problem.
Old Jun 7, 2004 | 07:25 AM
scott88vr6's Avatar
Well, I went outside, started my car listen when I started it up, and then "click" I heard the solenoid pop and then it started working. I guess I need to relocate the fitting. Thanks guys.
Old Jun 7, 2004 | 11:14 AM
scott88vr6's Avatar
Well guys, thanks for the suggestion, just went home and swapped it to the manifold before the solenoid. Seems to be working more resposively. I always had wondered on startup why the gauge took a second to run vaccum. Oh well, thanks alot for the help much appreciated.
