Gears get stuck when race shifting? PLZ HELP!
Old Jun 12, 2004 | 02:01 PM
XRS-Lift's Avatar
Hey i recently changed my clutch and now i cant shift when racing. if i rev high {7k} i cant put the car in the next gear. Do i have to change my tranny fluid to something else? Right now i have mitsu spec fluid. And is it even the tranny fluid thats causing thhis? If i got redline tranny fluid would it solve my problem? plz help!
Old Jun 12, 2004 | 02:20 PM
leonard_shelby's Avatar
sounds more like an install problem w/ the clutch
Old Jun 12, 2004 | 02:40 PM
BMan's Avatar
If you put in a high counter weighted clutch and didn't change to a stainless hose you could be blowing up the hose and not releasing or you could have air in the line.
BMan
Old Jun 12, 2004 | 10:31 PM
XRS-Lift's Avatar
BMan
I got the RRE X-clutch which is a much higher pressure plate load. I have the stock line. I got the braided line but my stock clutch died the same day i put it in so it got me worried. U think changing to the braided line will fix it? By the way shifting goes in just fine when im not near redline. I only have trouble near redline.
Old Jun 13, 2004 | 02:36 PM
XRS-Lift's Avatar
Bump. Anyone?
Old Jun 13, 2004 | 02:50 PM
chinto's Avatar
possably syncros ( spelling ) mitsu is rebuilding my trannie because of grinding at higher rpm shifting still stock execpt for air in take but possably same thing and iv been driven stick since i was like 10 so possably ya just got a bad trannie like me iv had it about 7 months and about 12k miles on it. hope this migh thelp.
Old Jun 13, 2004 | 02:57 PM
mitsuorder's Avatar
I'm having a similar problem, plan on rebleeding my slave cylinder, I would suggest the same to you.
Old Jun 13, 2004 | 03:02 PM
Boost Solutions's Avatar
Check your clutch's adj, what is happening is that your clutch is not fully releasing when trying to **** fast. Causing your clutch disc to drag on the flywheel which doesn't let your transmission gears slow down fast enough causing your syncros do work harder or in your case not work at all.
Old Jun 13, 2004 | 11:40 PM
timzcat's Avatar
The line may help as you will experience more backpressure from that pressure plate on t he hydraulics. Also if the restrictor is still in place it would also help free up fluid flow to the slave cylinder. Your problem is not enough travel from the slave cylinder. Be careful with pedal adjustment because the direction you need to go to gain more travel can cause the piston in the master cylinder not to seat fully and leave residual pressure in the slave cylinder, thereby slightly releasing the clutch. Adjusting the pedal to the factory spec is a great idea and I don't think enough people have looked at it. I adjusted mine to spec a long time ago and can tell you it was out by the spec. This was with very little miles on the car so it came that way from the factory.
If all else fails then it may be a problem with the presure plate, but I am sure you don't want to hear that.
Old Jun 13, 2004 | 11:44 PM
ducaticorse's Avatar
Could check into bad/malalinged syncros to.
Old Jun 14, 2004 | 10:46 AM
XRS-Lift's Avatar
cool ill see if my dealership will adjust my pedal for me.
Old Jun 14, 2004 | 05:02 PM
mitsuorder's Avatar
can anyone give me a how to on adjusting the ****ing clutch pedal, I just spent 15 minutes on my ****ing back in the hot *** texas sun trying to find this adjustment bolt or whatever the hell it is, someone help me out here, I really don't know what the hell I'm looking for, I turned a nut that was on a long gold bolt pretty high up the clutch assembly and couldn't adjust ****, I'm confused and it's hot as hell out there. Would love to get this done by tonight so would greatly appreciate any help from you guys/gals.
Old Jun 14, 2004 | 06:22 PM
XRS-Lift's Avatar
Thanks to the help of Blak94GSX I fixed the problem. Hopefully it will stay fixed. What I did was loosen the lock nut on the rod right above the clutch pedal and turn the rod clockwise {when facing the front of the car} half a turn and then tighten the lock nut. Broke all wheels loose shifting to second like usual. If the problem comes back {hopefully not} ill post, if not, it works. Thanks everyone
Old Jun 14, 2004 | 06:24 PM
XRS-Lift's Avatar
lol i know ur pain i just went through it. Ok u were probably turning the right bolt. Its far up and connected to that rod that goes into the firewall in a black rubber thing. Loosen that nut, then u have to use pliars or sumthin cuz its greesy. Turn the rod towards the gas pedal {right} half a turn then tighten the nut again, drive ur car and see how it feels.
Old Jun 14, 2004 | 07:09 PM
mitsuorder's Avatar
k, got it done, thanks for the advice, I figured it out as a mosquito perched on my eyelid btw, NOT a job for anyone claustrophobic. shifting at high and low rpm's seems much better now, will push it on the highway entrance ramps tonight.
