ATS 3 plate install problems
Old Jun 15, 2004 | 06:23 AM
jerastan's Avatar
Question ATS 3 plate install problems
Has anyone else actually been able to install the ATS 3 plate carbon clutch? Mine is just not fitting right. I know some people are running it. What's the trick????
Thanks,
Jeremy
Old Dec 18, 2005 | 06:50 AM
RS2's Avatar
RS2
Going through the same thing
Could anyone provide a step by step on how to install this clutch ? should I re-use my stock throw out bearing ?
Old Dec 18, 2005 | 07:10 AM
TopSpeed's Avatar
I have installed about 3 of them... never had any issues with the install. Everything went like clockwork. Actually have the triple carbon clutch in the shop car, and its been in there for over a year with 400+ launches and no issues. All you have to do is follow the directions on where to shave the bellhousing, flip the clutch fork, set the end gap on the clutch rod at 3mm. And your done, its not very hard.
Doug
Old Dec 18, 2005 | 07:25 AM
EVOlunchbox's Avatar
Doug,
How far off of the floor is your engagement with the ATS? I am all out of adjustment and I'm still not getting the right height. Any suggestion?
Old Dec 18, 2005 | 07:33 AM
TopSpeed's Avatar
Everyone I have done has engaged about 1/2 to 2/3 from all the way up.. about the same distance as the stock one.
Old Dec 18, 2005 | 01:55 PM
Mine doesn't? I'll PM you.
Old Dec 18, 2005 | 07:20 PM
jerastan's Avatar
The ATS should have come w/ a Toyota throw out bearing. Dan @ Godspeed helped me out a LOT w/ mine about a year or so ago.
Old Dec 18, 2005 | 07:34 PM
RS2's Avatar
RS2
Can anybody scan the diagram or step by step instruction that came with their ATS clutch ? mine is in Japanese
Old Dec 20, 2005 | 05:52 AM
4G63>OOOO's Avatar
I can fax it to you.
TwStDeVo
16
Jan 30, 2017 06:54 AM
mhd
Oct 25, 2014 01:34 AM
alanarias22
Jan 29, 2011 09:49 AM
pennies_hatchie
May 24, 2010 06:24 PM
EVOLV3D
Dec 13, 2007 01:10 PM
