Got Headstuds?
Old Jun 16, 2004 | 09:37 AM
darkhorse's Avatar
Got Headstuds?
Old Jun 16, 2004 | 09:50 AM
darkhorse's Avatar
this may help clarify what you are looking at in the picture. This should hold the head and the gasket a teensey weensey bit better.
Attached Thumbnails Got Headstuds?-evodeckstud3.jpg   Got Headstuds?-evodeckstud2.jpg
Old Jun 16, 2004 | 09:56 AM
Quickshift's Avatar
Haha just a little stronger lol
Old Jun 16, 2004 | 10:47 AM
Hooptie157's Avatar
What is that a toothpick LOL!!! Nice work as always. I gotta swing by your place and get an estimate of headwork ASAP.
Old Jun 16, 2004 | 01:21 PM
EvoJimbo's Avatar
So Christen, waht is this gonna cost us?
Old Jun 16, 2004 | 08:05 PM
darkhorse's Avatar
Money wise, or time wise? Actually the studs are really not much more than the std ARP studs for the EVO head. The only catch is that the motor has to be apart to do the mod. The head has to be opened up to fit the studs, the head gasket has to be opened up to fit the studs, and the block has to be dialed in, drilled, counterbored and tapped to fit the studs and insure that they are straight and that everything will line up when it comes time to put it back together. Ohterwise it looks like a porcupine. I also spot faced and dropped the head nut washer seats to make sure that there was 100% surface contact. There is no way to safely do this type of work with the motor in the car, you cant risk having the iron chips getting down in the engine. and the head must be off. I just was sharing with you guys what I was doing. Not saying that this is necessary for everyone. But if you are running big loads, this will certainly help. Bottom line, if you spit the head off or the gasket out with those pulled up tight, then I dont know what to tell you.
Old Jun 17, 2004 | 01:48 PM
Eric Lyublinsky's Avatar
Wow, those are thick
Old Jun 17, 2004 | 02:03 PM
darkhorse's Avatar
thats what she said
Old Jun 17, 2004 | 02:10 PM
Originally Posted by darkhorse
thats what she said
Really about you Glass or do you have two *******?
Key work "those"...
Old Jun 20, 2004 | 07:21 AM
ferrarokid's Avatar
Old Jun 20, 2004 | 08:07 AM
GottaGoFaster's Avatar
Originally Posted by ferrarokid
Could ya get any smaller of a turbo??
Old Jun 20, 2004 | 09:16 AM
Willie's Avatar
Tell you what
That turbo is a no joke it can swallow any small creature that come close including your arm .
Old Jul 5, 2004 | 02:11 AM
SSIR MIRAGE's Avatar
head studs
hey im really interested in those head studs.
are they for a mirage 4G15 engine?
im after some for this engine.
ive been looking everywhere for head studs for my engine.
ive tried ARP but they dont make it for this engine.
can you give me some more info.
thanks!!
if you have some for this engine ill buy some right away!
Old Jul 5, 2004 | 01:36 PM
darkhorse's Avatar
I would need to know the length of the original studs or bolts you have in your engine. If any different, they can always be made.
Old Jul 5, 2004 | 08:08 PM
yeah sure! I can either take a photo of it and give you the measurements or i can send you the actual head bolt and you can get the exact measurements off it.
Will they be ARP ones? or will they be as strong as ARP ones? head bolts or head studs?
let me know.
thanks
