New Downpipe with Stock Cat
Old Jun 18, 2004 | 09:01 AM
AWD_SR71's Avatar
I've already got the 3" cat-back exhaust - and I intend to keep the stock 2.5" cat for the next year or two - so here's the downpipe question:
Is it a good idea to replace the stock downpipe with either a 2.75" or 3" downpipe since I'm keeping the stock 2.5" cat - or will this combination result in some undesired results?
And if it is a good move then what would be a better choice - the 2.75" or 3" downpipe (given the stock cat)?
RallySportDirect has a good deal with free shipping on a Perrin 3" downpipe, but Perrin recommends replacing a cross-brace as well for pipe clearance which brings the total cost up to ~$450 is this worth the gains of a 3" pipe (with a stock cat)?
Old Jun 18, 2004 | 09:06 AM
4g63powered's Avatar
I think you wouldnt have any problems. I think you would see a quicker turbo spool. Thats what i got out of mine. The stock cat should be fine. I dont think you should see any negative results. If you dont mind, why do you want to retain the stock cat?
Old Jun 18, 2004 | 09:20 AM
AWD_SR71's Avatar
I've only got 1500 miles on the car so I'm trying to keep the visible mods to a minimum to avoid warranty issues with the dealer - I don't really want to touch any of the smog equipment and risk a CEL or find out I've voided my warranty.
Although I do see that Buscher has a 3" downpipe (that they claim doesn't require replacing the cross-brace) with a 3" high-flow cat which would come out at about $450 plus shipping.....decisions, decisions....
Old Jun 18, 2004 | 01:51 PM
tarmacBANG's Avatar
I know this question is kind of off topic, but will the Buschur High Flow Cat bolt to a HKS Hi-Power Catback?
Old Jun 18, 2004 | 02:06 PM
boomn29's Avatar
If you're not replacing the cat, I'd just wait. Things might match up, but they won't be 100% perfect.
Old Jun 18, 2004 | 11:09 PM
oguratevo's Avatar
I got an HKS downpipe(2.6") with stock cat and HKS hiper exhaust. quick turbo spool up than stock set-up.
Old Jun 19, 2004 | 07:54 AM
Ultimate Racing's Avatar
If you're certain you're going to stick with the factory cat, I'd recommend going with a 2.5" Downpipe. We have a nice one in stock which will bolt to your stock cat. As well, we eliminate the factory donut gasket (big restriction there), and include a double braided stainless steel flex section. At $275, I think it's a great deal. Let me know if you're interested.
Darryl
Old Jun 19, 2004 | 08:35 AM
Evo442's Avatar
Some tuners reccomend a 2.75 inch downpipe if you are sticking with the stock turbo. Faster turbo spool, good power gain, no loss of torque. Works is one of those tuners. I have their 2.75 inch downpipe. It bolts right up to the stock cat, works great.
Old Jun 19, 2004 | 01:44 PM
marksae's Avatar
Ditto. The HKS downpipe matches up w/ the stock cat perfectly. I measured the stock cat inlet diameter and it's right around 2.5-2.6". Can't beat the factory like fit and the high quality of the HKS parts.
Old Jun 19, 2004 | 01:50 PM
evo542's Avatar
i you should go with the 2.5in downpipe, so it's the same diameter as the stock cat
