Transfercase is about to go boom i believe......??????HELP!
Old Jun 19, 2004 | 10:40 AM
EvoG8r's Avatar
My transfer case makes a horrible noise. The shop that did my clutch put synchromesh in transfer case and the same problems happened after 150 miles of driving. I'm sure Mitsu will warranty it because it's their fault.
Old Jun 19, 2004 | 11:09 AM
hotrod2448's Avatar
Where are you at in NC?
Who is your district rep.?
As far as the lemon law goes you probably wouldn't have to go that far. In NC the requirements to meet the lemon law are 4 attempts to fix the exact same problem or 20 working days(monday through friday only, even if they work saturdays) out of service in a year. However if you have enough problems and raise enough hell but, still act professionally you stand a good chance at a "courtesy buy back".If you look for my thread titled "unf**kingbelievable" in Evo General there may be some info to help you in there.
Old Jun 19, 2004 | 11:28 AM
evorent's Avatar
Originally Posted by BaLListic_EVO
ok driving today my car decides it wants to start making a really high pitched whine.... this being 678miles after i just had a clutch installed....... Basically this whine consist of get the car up to about 45 and it starts making it and gets louder with speed..... about 75mph its loud enough it sounds like a fire siren........ If this breaks and it doesnt get covered under warranty as far as im concerned they can repo the ****ing car! My car is all stock....... sucks ***! i will never buy another mitsubishi!
for sale?
Old Jun 19, 2004 | 11:36 AM
sr20det91's Avatar
Cut a hole in the bell housing???? At the dealer? I asuume because they didnt know there is an access hole to release the throw-out bearing. Which probably means they were not even looking at the FSM. If they were this incompotent, its hard to tell waht else they screwd up in there. Id say its definitly from a bad install. Contact your district rep. immediatly. You should be able to that that covered for free, including a new tranny.
Old Jun 19, 2004 | 11:41 AM
hotrod2448's Avatar
Oh, I forgot.Contact the Mitsu customer service line and let them know you want to file a case with them on your car not being fixed prperly and also let them know that the dealership screwed up things that weren't broke to start with. If you have to go to arbitration this will be helpful. It will also get Mits. to start putting some pressure on the district rep. to get cracking.
Old Jun 19, 2004 | 11:52 AM
BaLListic_EVO's Avatar
ehhh yeah mine is my transfer case..... its about to explode...... lol
Old Jun 19, 2004 | 02:15 PM
nice this is exactly what i wanted to hear... i went by there today and got ahold of the owner he refused to give me a rental! so i said ok ill drive it till it breaks then i guess because i cannot be without a car..... The new tranny prospect sounds good btw. As for location im in the middle of the state around greensboro these guys havent been trained on DSM's Evo's Anything awd.... they were just guessing.... The best part is how one guy took it apart and a totally different person put it back together thats the intelligent way . They managed to strip a bolt out on the underside of the car that they had to re tap and then when i brought it back in because it was making noises i went over and took a bolt out of the underside of the car by hand....... this is actually getting funny i guess..... anyway what would i have to do to get ahold of the district service rep????
Edit: please ignore my jumbled up typing im really pissed at the moment....
Old Jun 19, 2004 | 02:34 PM
PHILLY EVO's Avatar
HERE IS MY PROBLEM Had A New Clutch Installed Two Weeks Ago. It Was Fine Untill A Couple Of Days Ago. I Noticed It Was Getting Hard To Put Into First Gear When I Would Stop At A Red Light / Stop Sign. Now It Started To Do It In 2nd... I Have To Turn The Car Off And Put It Into 1st Gear.....
Today
I Made An Adjustment Behind The Clutch Pedal Ad It Is A Little Beter Every Once In A While It Does It Now......
The Other Problem I Have Happen A Few Days After The Clutch Was Installed. When I Let The Clutch Out In First Gear And Start To Roll It Makes A Loud Winnie Nose And Goes Away When The Car Rolls. When The Clutch Is Let All The Way Out It Stops.
The Clutch Is An Exedy Hyper Single Disk, New Throw Out Bearing, And Flywheel..
Anybody Have Any Info On This..........
Old Jun 19, 2004 | 02:57 PM
u trying to hijack my thread
Old Jun 19, 2004 | 03:08 PM
evoguy's Avatar
I had the same problem after changed my clutch. They didn't service everything right and I blew the transfer case. They tried to blame me........ Eventually got it replace under warranty.
Old Jun 19, 2004 | 03:24 PM
ducaticorse's Avatar
I hear you bro, my evo is a piece of ****e to. I've had nothing but problems with it, I'd like to light the piece on fire.
i honestly wish i would have got the WRX STi this car ****ing sucks! Its been one problem after another.... **** im about to call lemon law hell the thing is even the color of a lemon it should have tipped me off.......
Old Jun 19, 2004 | 03:36 PM
BadazzCR's Avatar
The Evo transfercase must have SAE 90w in it. Any other type of fluid will cause the ring and pinion inside of it to FAIL
Hope your ready to buy a new transfercase or hope you get whomever worked on it to fix it.
Old Jun 19, 2004 | 11:19 PM
They Better warranty it or i will drive this ****in piece of **** thru there front window about 70mph then if i survive they can repo the pile! At this time they need to not **** with me too hard... i have been layed off and just trying to make ends meet and make this damn payment off unemployment. so all i got to say is FUUUUUUUUUUUUUUUCK
Old Jun 19, 2004 | 11:41 PM
bobaab's Avatar
sorry to hear man, hope everything will get resolved in the end!
just make sure what the lemon law is in your state, it varies from state to state.
Old Jun 20, 2004 | 03:19 PM
yeah im going to speak to a lawyer come monday....
