Ceramic coated exhaust
Old Jun 26, 2004 | 12:45 PM
EVOeight's Avatar
Arrow Ceramic coated exhaust
I ported, polished, and ceramic coated the factory exhaust manifold and O2 housing (turbo dump). Let me know what you think. (56K be patient)
http://users2.ev1.net/~subaru/evo_web/evo_exhaust.htm
EDIT: to add picture
Old Jun 26, 2004 | 01:02 PM
fimotorsports's Avatar
nice write up, I may go through performance coatings if there turnaround is good.
Old Jun 26, 2004 | 02:58 PM
BuLocal's Avatar
Awesome write up.......where did you get the thermal-wrap?
Old Jun 27, 2004 | 06:13 AM
EVOeight's Avatar
You can get the ThermoWrap, the straps, and the high-temp paint from SummitRacing.
Old Jun 27, 2004 | 07:23 AM
evo_dadi's Avatar
very impressive man!! have you dyno'ed it yet?its a definite alternative to buying the aftermarket products
Old Jun 27, 2004 | 08:23 AM
mifesto's Avatar
a quick question.. if i just use polish off all the rust on the manifold...... give it couple coats of paint and a few coats of clearcoat.. would it prevent rusting?
Old Jun 27, 2004 | 12:11 PM
maikonkun's Avatar
Thumbs up
Nice write up and pics.
I am curious, what was the clearance between your downpipe and oil pan at it's narrowest point ( estimate OK ) ? And how many millimeters thick do you think the wrap was after being applied ?
TIA
Old Jun 27, 2004 | 02:31 PM
EVOeight's Avatar
I just don't know how well painting the manifold would hold up. I think it would eventually flake off and rust. I am hoping that the ceramic will last for many years.
The thermowrap is approximately 1/32" thick but is overlapped so I guess it is 1/16". It clears the oil pan by about 3/8 of an inch at the closest part.
Old Jun 27, 2004 | 05:34 PM
Guerillah's Avatar
evoeight,
What tools did you use for the porting and polishing? Was the porting tool able to reach into all places inside the manifold, if not what did you use to get it to reach?
Old Jun 27, 2004 | 05:47 PM
mifesto's Avatar
even if its high temp paint with clear coat?
Old Jun 27, 2004 | 06:38 PM
bolsen's Avatar
Pardon my ignorance, but what's the anti-lag bosses? What do they do?
Old Jun 27, 2004 | 06:52 PM
EVOeight's Avatar
I used a straight die grinder and an angle die grinder and several long bits. I also used my Dremel tool with the flex-shaft to reach those difficult areas. I was able to reach everywhere inside the manifold.
You can get 2000 degree paint but not clear coat, at least not that I have seen.
The anti-lag bosses are those two cylindrical bosses between runners 1&2 and 3&4. In some countries those two areas are drilled and tapped into the exhaust ports and has some kind of air injection to keep the turbo spooled up all of the time (at least that is what I think they are for).
Old Jun 27, 2004 | 07:49 PM
Karash's Avatar
Yea I still havent seen a definate answer about the "anti-lag" bosses. I see them on every single JDM picture on the net tapped with that tubing.
Old Jun 27, 2004 | 08:12 PM
Guerillah's Avatar
This is what a gtfour looks like with antilag all wired up.
Description of how it works on a gtfour (probably the same way mitsu does) is at http://gtfour.supras.org.nz/homologation.htm
Old Jun 28, 2004 | 04:53 AM
EVOeight's Avatar
I will never use the anti-lag on my car though, it is very hard on the turbocharger...
