Who has plug and play o2 sim?
Old Jul 9, 2004 | 01:53 PM
dryad001's Avatar
I am looking for if it even exists an O2 simulator the will plug into the factory harness. If I have been reading the threads right the is a connector for the rear 02 under the passenger front seat, right? Any help would be great.
Old Jul 9, 2004 | 02:01 PM
WannaRace's Avatar
Yes, Buschur Racing sells them. Call them to place the order as it is not on their website. I believe Lancershop.com sells them as well but have no experience with their unit.
Old Jul 10, 2004 | 08:05 AM
tweakdsm's Avatar
www.o2simulator.com $30 bux shipped! in 3 days you will receive o2 sim in mail....
what i did i removed passanger side seat there is an opening in carpet
you will find connector inside remove it, cut the white wire before the connector and connect it with white wire on the o2 sim, other end just leave it alone - red/yellow is +12, (splice connect) use electrical tape black is ground (splice connect) thats all! and dont forget to disconnect your - terminal before installation
thats all no more ce light (o2 sim led with blink every 10sec or so)
later.
Old Jul 10, 2004 | 11:15 AM
EvoTio's Avatar
tweakdsm, thanks for the tip. I'll be ordering one of those soon.
Old Jul 10, 2004 | 02:37 PM
4ce fed's Avatar
I think the point of his question is that he doesn't want to cut any wires. Stuff that plugs in also unplugs to return to stock when you need to.
Old Jul 10, 2004 | 03:22 PM
dryad001's Avatar
Thank you for the responses buy 4ce fed is correct I do not want to cut any wires.
Old Jul 10, 2004 | 03:43 PM
ColinL's Avatar
I believe the easiest way to do that would be to buy another 2nd o2 sensor-- someone that has aftermarket ECU wouldn't need it, otherwise buying new kinda sucks-- and use the connector from it to splice into your simulator.
Being OBDII required, a second o2 might be fairly standardized, so maybe you could get one from a junkyard. I'd pull the stock one and bring it with you to the local yards if you wanted to try that route.
Old Jul 10, 2004 | 05:16 PM
tweakdsm's Avatar
evotio: n/p...
Gibby860
11
Sep 16, 2009 05:15 PM
rlui0514
Jun 25, 2009 01:12 PM
smokedmustang
31
May 26, 2009 04:38 PM
ethompson
Nov 1, 2007 02:23 PM
lexat20
Mar 22, 2006 11:23 AM
