ECU pulls timing when RICH??
It will not pull timing because of a rich condition. I am not possitive about this: but i think the ecu will add fuel and pull timing when a knock event takes place. I know the motronic ecus do this, but i am not sure about the evo.
The reason for this question is because right now my car is so pig rich my UEGO gauge won't even read it. it is probably around 8 or 9 something to 1...........So my car doesn't run.........Even at full boost, my car chokes...........
It sounds like you may have a major boost leak then. Check all couplings and makes sure no pipes have popped off. How does the car run?....it should studder and barely move if its that rich.
edit: also what sort of fuel management are you running?
I am pretty sure I ain't got a boost leak as I checked everywhere. I am also not using the stock ****ty couplings that pops off. I currently don't have a fuel management system but will be getting my re-flash soon. I had a flash done months back and my car had only a catback on. Now I have whole 3" turboback, intake, boost controller, 02 housing, 264/264, crank pulley, UR intercooler piping, and a high flow cat. I am thinking all those mods after the flash is causing the lean conditions as any mods will throw off air/fuel ratio.
Originally Posted by NRG
I know that the ECU will pull timing when too lean of a condition but does it also do the same if condition is rich??
my 2c,
shiv
FS[SouthEast]: FS: GG 2006 Evo IX (50k miles)
rich3389
For Sale - Cars For Sale
10
May 19, 2015 01:23 PM
