Read before installing AEM cam gears!
Old Jul 26, 2004 | 10:50 PM
craighardy's Avatar
I recently installed HKS 272 cams and the new AEM Tru-time cam gears. The gears are well made and now have 5 bolts but after recently having my car tuned I was told that the advance and retard labels are backwards! Just thought I should share this info!
Craig
Well I just figured out where the confusion came from. The Vishnu gears have the marks on the outer gear with the teeth and the AEM gears have the marks on the inner part of the gear. This means that on the Vishnu gear the left side of 0 is Retard but on the AEM gear it would be on the right side. Easy mistake, looks like they are correct after all, sorry guys!
Old Jul 27, 2004 | 06:13 AM
NOVA EVO's Avatar
Old Jul 27, 2004 | 06:46 AM
marksae's Avatar
Got any pics of the gears?
Old Jul 27, 2004 | 07:36 AM
Karash's Avatar
How the hell can they be backwards? AEM is a bigass company...thats amazing if true. (and I would fire their quality control person)
Old Jul 27, 2004 | 09:33 AM
EvolvedDSM's Avatar
Did you install the intake gear on the exhaust cam and vice-versa?
Old Jul 27, 2004 | 10:04 AM
marksae's Avatar
That shouldn't matter as both cams still spin the same way. Do our engines spin clockwise or counterclockwise?
Old Jul 27, 2004 | 10:09 AM
Fenris Ulf's Avatar
LOL, I have to see how one timing chain can drive two cams in opposite directions when wrapped around the top of both cam gears!
Old Jul 27, 2004 | 11:14 AM
EvolvedDSM's Avatar
It's a belt smartass... Give me a break, I just woke up
Old Jul 27, 2004 | 03:01 PM
DrEvo's Avatar
Issue resolved, correcting my post.
Old Jul 27, 2004 | 03:52 PM
marksae's Avatar
I just read in the manual in the timing belt section to see which way our engine rotates. It’s clockwise. So the AEM cam gear is labeled backwards.
Old Jul 27, 2004 | 04:09 PM
DrEvo's Avatar
Thanks for checking Marksae.....
Old Jul 27, 2004 | 04:14 PM
Jorge T's Avatar
Maybe they're made for the Eclipse engine?
Old Jul 27, 2004 | 04:18 PM
BadazzCR's Avatar
that aem gear in the pic is not for the evo
Old Jul 27, 2004 | 05:26 PM
craighardy's Avatar
I don't have a digital camera right now but so I can't post pics. The picture of the AEM gear above is not for the EVO. My gears are labeled the other way, A is on the left of TDC and R is on the right. Is this correct? Most other gears simply have marks but no labels so I don't have anything to compare these to. Like I said, I was told by a local shop that they're backwards.
Thanks,
Craig
Old Jul 27, 2004 | 05:44 PM
Quickshift's Avatar
Evos engine turns clockwise if you are facing the gears. Backwards would = advance aiming counterclockwise and vice versa for the retarding of the cams.
