To cam or not to cam that is the question.
meta. why would sticking to stock cams give you a better bootom end? the grater the lift on the cam and the grater the duration at 1mm the quicker the spool up is. the quicker the spool up the better the bottom end! are my thoughts wrong?
thanks Chris.
thanks Chris.
Sorry guys try this
http://f2.pg.briefcase.yahoo.com/gtvanhorn
Select the video folder then right click and saveas for the video
Hey GTVEVO,
Thanks for taking the time to create and post that video.
I'm not sure if it's the video or not, but I don't think that car sounds as smooth as stock when idling. I see you have the 264/272 combo. Could someone with straight 264's comment on that vid? I was under the impression that straight 264's sounded very close to stock, but now I'm not sure.
I realize that some people like or don't mind a rough idle, but I prefer it to be as smooth as possible. For example, I don't want it to sound like I have a cam upgrade. The car in the vid def sounded like it had one to me. Maybe that's not even possible with any cam upgrade.
Originally Posted by 95GSXtoEVO8
Hey GTVEVO,
Originally Posted by boomn29
I have a friend with JUN 272/272 and cam gears, and his idle has that mean looping sound too. It's kinda neat. It sounds like it's going to die, but never does.
Everyone, I put another video out there with Zero at the end of it. This is a video of HKS 264Intake and 272Exhaust cams with the Cam Gears set a zero. Less looping so more of a stock sound. You still can hear a small difference compaired to stock but idle is much smoother than with the gears retarded so I hope this helps with your decision on them.
I completely forgot I started this thread. I am so glad everyone is putting in their thoughts and merging other threads to help out. The decision making process is still so difficult. We have people who feel HKS is top notch due to its construction and performance. And there are others who feel that Jun or the rally cams are better with added springs. ?????....Man...this is tough. I dont plan on buying cams to sell them for a new pair. How much est. difference is there in HP given the same mods with the more aggressive cams...say HKS 272's versus.
Thanks
Thanks
If you want low mid and top go with 272in 264ex HKS. Look at my 1/8th mile time. I recently ran a 7.5 at 93mph on pump gas! I can't possibly see how stock have mor low.
If Bucher said it I believe it, but am sticking with what I have.
No I meant 272in and 264ex. People in England experimented with it and with cam gears you can pull more overall power than any other combo. They all run this combo over there. My low/mid hits so hard that with race fuel I break all 4 loose at a roll stepping on it. I chirp 1-2 2-3 and 3-4 feels like a launch but no chirp. You won't be disappointed.
Originally Posted by EVO8LTW
Springs on 2G aren't the same as an Evo. It remains to be seen whether stock Evo springs can survive long term with higher lift cams.
Cusco twin disc clutch - No I'm not worried. I bought and built my EVO to drive hard not worry. It sucks when it breaks. I'm not rich, I'm in the military. I'll be going back to Iraq soon so if it breaks oh well. I plan on getting my tranny and transcase built anyways when I'm gone. I can't wait. Later.
Matt
Matt
Matt
Matt
