Crunch in 2nd and 3rd gear
Old Sep 12, 2005 | 04:17 PM
  #31
vtecwrecker's Avatar
Originally Posted by USAF_STi
Mine also does this. it has done it since i got it 2 days ago. i will schedule an appointment with the dealer this week.
dont forget to let us know what they say..
Old Sep 12, 2005 | 04:36 PM
  #32
CeeNiK's Avatar
how hard is it to drain your transmission oil in order to replace it with Penzoil syncromesh?
Old Sep 12, 2005 | 07:58 PM
  #33
USAF_STi's Avatar
I have never done the transmission on an Evo but it should not be hard. How many quarts of tranny oil does it take to fill it?
I will let you guys know what the dealer says. i go on wedensday.
Old Sep 12, 2005 | 11:31 PM
  #34
nj1266's Avatar
The dealer more than likely will tell you that this is normal. The tranny will loosen up with the mileage.
Also it is not hard to drop the tranny fluid and put the 3 quarts of Penzoil Syncromesh.
Old Sep 12, 2005 | 11:48 PM
  #35
Evo_Jay's Avatar
Im pretty sure most EVOs do that, mine did, and I also made a post about it, change my tranny fluids, removed restrictor, SS clutch line, adjusts pedal, etc. and nothing fixed it
BUT last week when I hit a little over 9K miles, I notice that the notchyness of the 1-2 & 2-3 shifts improved greatly and I have heard that the EVO is like that.
Old Sep 14, 2005 | 04:11 PM
  #36
so what did the dealer say? mine is getting so annoying. sometimes it goes away for maybe 5-10 shifts, and then it comes back. doesnt matter if i shift fast , slow, high rpm, low rpm. does it anyway.
Old Sep 14, 2005 | 08:21 PM
  #37
Nood1es's Avatar
I have a 05 with 4k miles no mods and i get a 2nd gear lockout downshifting from any higher gear. Anyone else? or should i just take to the dealer?
Old Sep 14, 2005 | 10:30 PM
  #38
USAF_STi's Avatar
I actually didnt get to go but when i talked to the tech on the phone he said it is normal, especially on a low mileage Evo. i will change the fluid this weekend see what happens.
Old Sep 20, 2005 | 05:43 PM
  #39
deffro's Avatar
Mine does it too. 1200miles on an '05
Old Dec 5, 2005 | 03:30 PM
  #40
Dr.Sound's Avatar
any updates?
i have the 2-3rd crunch as well.
is BG Syncroshift fluid GL-4?
Old Dec 5, 2005 | 03:35 PM
  #41
Doogie Howser's Avatar
engine dampener, kb base bushings, underhood 2 pc bushings, change tranny fluid to oem spec, readjust clutch, move seat up, be more smooth btw. your gear changes
Old Dec 5, 2005 | 03:41 PM
  #42
Dr.Sound's Avatar
which is OEM spec fluid?
Old Dec 5, 2005 | 04:32 PM
  #43
worksevo8's Avatar
Is this occurring on only 05's? or are the 06's affected also. Thanks.
Old Dec 5, 2005 | 05:12 PM
  #44
Your in luck, I actually have my manual on my workdesk.
Straight from my 06 IX non-ssl manual OEM manual transaxle fluid (transmission)
Vehicles with 5M/T
Lubricant: DiaQueen New multi gear oil API classification GL-3
viscosity range: SAE 75W-80
or
Lubricant: Gear Oil API classification GL-4
Viscosity range: SAE 75W-85 or 75W-90
Vehicles with 6M/T
Lubricatn: Diaqueen SUPER MULTI GEAR OIL (GL-4), or exact equivalent
Viscosity Range: 75W-85
I would not try and mix and match fluids or try and buy a cheaper alternative. I would just stick to whatever the manual suggests or any other fluids proven to work by members of evom.net
Old Dec 5, 2005 | 05:39 PM
  #45
Dr.Sound's Avatar
^ ok, so this is what is used in cars from factlry......correct?
what are better oils that are classification GL-4 or GL-3?
is BG Syncroshift fluid GL-4 classified?
thanks for the info btw
