HKS EIDS install and help
Old Aug 2, 2004 | 10:06 PM
carbonevo8's Avatar
ok here it is guys first i'll list my mods and then the problem im having
K&N Intake
Works throttel body
Works cams
Works 93 P2 flash
Stock blow off valve venting right now (im gonna put my blitz on tomorrow)
3 inch turbo back exhaust
i have other mods but these are the only that will effect the idle.
ok i installed the HKS EIDS tonight and so far no stalls at all on the stocker BOV VTA. but when you slow down or come to a stop it only idles at 1200 RPM after awhile it will go down but it takes atleast 10 seconds.
I know this is a new product to us evo owners but im hoping someone has some experience thanks.
Old Aug 2, 2004 | 10:22 PM
Boston'sEvO-->8's Avatar
try resetting ure battery....leave the power of for an hour then try it
dEdiYT11's Avatar
You might try to slightly adjust the screw on back, but what the EIDS does is makes your RPM's drop at a much slower pace. Everything soulnd like its ok tho. Mine is like that.
Old Aug 2, 2004 | 10:28 PM
carbonevo8's Avatar
ok i wasnt sure if thats was correct or not ive never really played with one of these befor so ill try to rest the ecu in the morning but if this is the way its suppose to be is it ok to idle that high? also did you turn the screw on the back? if so how much? i tryed turning if but it seemed to get worse i have it about at a little under a quarter of a turn and so far so good. no stalls with the ac on and low rpm hard turns not even a putter.
i guess my main question is it ok to idle this high and does your idle down and then back up
Old Aug 2, 2004 | 10:30 PM
dEdiYT11's Avatar
ya its ok, but after a couple seconds the RPM's should go down.
carbonevo8's Avatar
oh yeah thanks guys for the quick responses i was getting woried if i could drive my car tomorrow soun ds like i can thanks
Old Aug 3, 2004 | 06:26 AM
areet's Avatar
Yup, I run mine in the middle, but I think it might be too high, just haven't been able to tune it since i'm waiting for my clutch get installed
Old Aug 3, 2004 | 12:43 PM
carbonevo8's Avatar
ok here it is guys. the hks eids works great i mean great it takes about a hour of driving and now its perfect i have no problems at all now i think it just takes a few runs so the ecu gets programed. i put my blitz bov on today and ive had no problems what so ever. install is extremly easy it took about 10 minutes.
thanks again guys and i would highly recomend this part.
Old Aug 3, 2004 | 01:08 PM
NOVA EVO's Avatar
I'm thinking of getting the EIDS as well...
Old Aug 3, 2004 | 06:30 PM
carbonevo8's Avatar
hey guys if you want a eids i got mine from http://www.hellboyzracing.webdesigng...ge/1171314.htm
he gave me great deal. i know its not on there website but just call and ask for it.
yet another great product from hks
Old Aug 4, 2004 | 03:26 AM
SSKILLA's Avatar
where do u guys have your scre set to?
Old Aug 7, 2004 | 11:36 PM
trinydex's Avatar
can you guys report back on how well this works?
Old Aug 8, 2004 | 11:15 AM
vletnguyen's Avatar
how much was it? lancershop has it for 124 i believe
Old Aug 8, 2004 | 08:46 PM
carbonevo8's Avatar
i have mine set almost all the the way turned down i only have it up a few notches. i have a few few minor mods as well. im not sure on the price ill give it to you tomorrow. later guys
Old Sep 8, 2004 | 07:22 PM
kayyoevo8's Avatar
i have a question for you guys.... how do you guys make an evo vent to air with the stock bov? also, i tried to vent the air with my stocker on and the eids intalled and i had problems with stalling around 5k rpm. whats up with that.. can anyone give me some info please?.....
